View Full Version : LT1 Based Engine Tech
- fuel pump replacement (trap door)
- How many miles on your car before you had a head gasket problem ?
- Cyberdyne Digital Gauges? Any luck with them?
- quick qeustion bout oil pressure?
- Doing my intake manifold now, quick q's!
- Strut tower brace
- ?'s regarding Magnaflow catback????
- Dynaspark/Delteq??
- Tell me where this wire plugs into!
- I need a clear answer to my walbro fuel pump question...
- 1.6rr's done, but some chatter.
- underdrive pullley problem
- what should i do about this leak?
- fans stay on longer with 160 TS
- Best LT1 HEADS???
- a dumb question
- Racetronix issue
- Got a link to a Griffin or Bee Cool or other aftermarket radiators for a LT1?
- 1993 lt1 Faulty DIS problem
- Valve seal ?'s
- weird spark problem
- Will this combo get me to stock LS1 territory or outrun one?
- Right bank lean!!!! HELP
- After CSI water pump install, temps up crazy, help me!!
- heavy fuel smell in car after driving.
- SS Impala exhaust questions
- Banks exhaust system
- Fuel Pump Installation problems...
- A fuel line fell off!
- !AIR! and !EGR! without tune?
- dual exhaust over both sides of axle
- Autotap or Scanmaster?
- Fan switch Question
- MAF 12 V wire
- Who is A.R.E.
- Thinkin about removing A/C?
- Hood Latch
- Mass Air Sensor
- Odd misfire today, any ideas?
- Which wire to tap into to install gauges so they dim like stock ones?
- time it takes for Madz28 tunning
- How long to install Longtubes
- Help, please
- Help! I may have screwed my opti.
- LT1 missing/misfiring badly, intermittent
- Car thrwoing Belts..
- Attn: Experts need help asap (shoebox)
- Just did 1.6rr's, engines flooded.
- Car Leaking Coolant When Shut Off.
- 1/8th mile times with hotcam
- Running car w/o CATS. Any problems possible?
- True Dual Exhaust and using Sweet Thunder Mufflers..
- LT1 Help Needed ASAP!!!!
- Hesitation and stalling
- Who ports out stock Throttle bodies
- Cylinder sleeving...what all is involved?
- Coolant Light On
- O2 sensor replacement
- Stumped by a slight surge...
- In Case anybody has a mystery coolant leak, just fixed mine.
- Areomotive AFPR on an LT1 ??
- High Flow Fuel Pump on a Stock Car
- Car won't start..... battery??
- How much power/gear to pull the wheels?
- I got a solution for my wanting of exhaust tone!
- Alternator or battery
- tb bypass
- Finally!!
- Lighter valves
- When is it time for an ignition upgrade & will it help?
- Car wants to die at an idle??
- '94 Z having problems
- won't start or turn over, battery isn't dead
- how to build a 383???
- feedback on this 383 combo
- 160 Stat, Pros and Cons?
- Finally!!!!
- Cutout, Open or Close?
- Will a cut out fit my stock exhaust
- Clogged Cat?
- LT1 Short Block
- Header install - Drop the engine?
- TR55 VS. Bosch Plat 4's
- Almost ready to build my 383..still have a few ?'s
- Just Went to track! Is this a norm?
- R&R LT1 Engine question
- Jet-Hot LTs sound clip
- The car has been sitting and now a huge tranny fluild puddle .
- These are the SPECS on my new motor, any comments appriciated
- coolant sensor
- Still problems w/ the car
- Just need a quick answer before i buy this part
- Sheetmetal Valvecovers?
- SLP Loudmouth Installed Video Inside
- What lifters to use with ZZ409
- Why get R lifters instead of the Comp OEM replacements?
- Emission Comp. Slip Fit Long tubes?
- Is anybody knows these guys? www.chspdx.com
- help reading my flow numbers please
- ATTN shoebox experts
- RiceMeter Air/ Fuel Gauge..
- New LT1 owner :)
- Plug Wires!!!
- Fuel Injectors
- where to find 4.11 gears?
- How many of you have replaced the Ignition switch??
- What should I look for with datamaster on my car?
- LT4 intake alteration-make sense?
- EGR Exhaust Man. bolt
- novice question on my CAM
- Launching Auto's
- Good resonably priced forged pistons for 355
- Tell me what to do to an unmolested set of LT4 heads/intake...
- How do you adjust the master cylinder on the Mcleod ST??
- Pushrod Length Selection?
- Custom Cam for stock heads HELP??
- car will not run at part thorttle or under load
- self or non self aligning
- WTF, dipstick broke while checking oil! what to do???
- EGR & solenoid replacement Q (the hesitation/stumble)
- What Does "Blending" After A Valve Job Mean?
- Where to get chrome valve covers that fit around alt???
- hit 2nd instead of 4th now motor stumbles
- What kind of mph should 390rwhp give you?
- getting melling m55a pump, what else do i need.
- Does anyone have the P/N for the opti spark O ring?
- HELP, Key wont turn... car wont start
- Rearend help?
- NJ Performance Shop
- Symptoms of fouled plugs
- Miss at idle (CONT'D) Burnt Wire?
- which cam to choose
- second biggest design flaw
- Buying XE224/230 Soon, Advice Please
- Partial throttle sputtering?
- What is the pipe I need for single cat headers on a dual cat car
- Anyone successfull at quieting true duals??
- Just Bought some Headers Have some Questions... please!
- Dino or Sythetic on 1st 50mile break in oil change??
- Someone please help me ... car is almost undriveable
- kyb agx adjustable people inside for shock tuning
- Interesting MAP issue/Possibly valve related???
- Interesting muffler info
- Opti Crap!!!!!!!!!!!!!!!!!!!!!!
- Best way to install gauages?
- Help please car died tonight wont start!
- Cam swap time again....
- Need plug wire help!!!
- what is going on with my car's computer or cable
- Low Oil Pressure
- What size is thep plastic tool needed to disconnect fuel lines???
- Lifter Guides
- Timing chain issues
- Will A Ss Ram Air Box Work With A Strut Tower Brace
- Cloyes timing chain install help PLEASE!!
- Slp Loudmouth
- car overheated today, went past red zone/help!!!!
- 383 Project Compelte (PICTURES)
- Poor Acceleration
- Starting the Adventure into Mods....
- HELP!Mallory to MSD wiring harness question...
- Car won't start after it rains?! Ideas??
- Code 24 need help.
- Looking for a picture-close up
- Best way to detect exhaust leak.
- dirty terminal
- Broken valve spring= No start?
- ARP Intake bolts part number?????
- Lucas Oil Additive any good or a vacuum pump?
- Overheating problems
- coil pack conversion
- Air fitting size
- Dual cats w/ '94-'95 AS&M headers??
- cam and valvesprings question
- Yes more cam help?????
- Coolent dye???
- Jet Hot Install Question
- LT4 Valve Springs
- Would Iac counts being 70 at idle hurt track times?
- O2 extensions
- Need help picking camshaft
- electrical gremlin??
- Cooling fans not engaging-PLEASE HELP!!
- LT4 head gaskets
- Very Intermittant Hard Start?
- Did Impalao blocks have different internals?
- What size ET streets for stock 16x8 rim?
- LT1 Tuneup
- Lash setting in a 97
- Stock cam rpm limit?
- What size line wrenches needed for the three brake lines on ABS unit?
- throttle body bypass
- how to run JUST the alternator with the tensioner belt?
- cam selection HELP?
- ses light
- LS1 to LT1 slave cylinder conversion???
- Racetronix kit and inline 255lp. Overkill?
- Head swap tips and suggestions
- valve adjustment/ valve to piston clearance
- Cylinder Head Qestion....
- Cam bearing worn down to the copper?
- Whats wrong with my car?? Hit a curb.
- bought 2500 stall what else do I need?
- chris @ jethot's email?
- cylinder head P&P specs + milling
- Stock Water Pump Failer questions??? And Electric pump ???
- Throwing code 42 need help please..
- How bad will a bad o2 sensor hurt your track times?
- Whats causing the rich condition?
- Do the stock V6 1.6 rockers fit LT1s? self aligning?
- 12-14 Miles Per Gallon - Basically Stock???
- My car Sucks.
- how much for clutch install
- Blowing Fan Fuse (#6)
- cc305
- Knock Sensor Removal.
- car trouble
- another fuel pump question!
- Code 43 ESC Failure ??
- Got a ?
- 30 lb injectors
- cause of high rpm miss?
- Highest Mileage when doing cam swap
- Should I lock up my torque converter at WOT in 2nd and 3rd ?
- Slp Cai?
- is it hard to take heads off 1996 z28?
- Problems w/ 1.6 rr's
- Wires touching
- torque converter by west coast converter
- Why arent my fans coming on?
- Does Tunercat show trouble codes?
- Car will not start
- Is my ~!@#$%^&*() Opti dead ?
- Water pump leak?
- that blue conector on the LT1 elbow
- Magnetic oil drain plug, where can I get one?
- Why should i hire a Pro to rebuild my ENG
- 2 different starters for lt1?
- What do you think about BBK cermaic caoted headers??
- CODE 28 ON A 93 lt-1 a-4
- Does FLP build a 3" y-pipe for their headers?!
- White greyish smoke
- 58mm Throttle body, which one ?
- SLP LT1 fuel pressure reg kit??
- Fuel Pressure!?!
- Slp Loudmouth Exhaust Lt1
- Part # needed (DRL module)
- wiring harness (shoebox help?)
- Just another car day
