coil pack conversion
Old Aug 4, 2004 | 02:46 PM
irishz28's Avatar
hey anyone have pics or any info on how to do the coil conversion. Are there any kits available or do i gotta find some LS1 camaro with no alarm?
Old Aug 4, 2004 | 02:56 PM
My Red 93Z-28's Avatar
Re: coil pack conversion
It's called LTCC. You might try searching it under that. I saw som pics of it but don't remember where at.
hope this helps.
Old Aug 4, 2004 | 02:57 PM
Do a "search" for "LTCC".... that's the black box that allows your system to operate using the Opti low res signal for cam position, and direct fire 8 LS1-style coils. There is a similar setup from "Delteq" that uses the ignition driver from the Northstar engine, and a 4-coil pack in "waste spark" mode.
Or, aftermarket ECU:
http://cjcfo.fbody.com/members/injun...os/Coils01.jpg
Old Aug 4, 2004 | 03:06 PM
irishz28's Avatar
im from NJ to bro. and is the conversion really worth it?
Old Aug 4, 2004 | 03:10 PM
I've been running without the full Opti for more than 5 years, first with the Electromotive Opti-Eliminator, and then with an aftermarket ECU using the Otpi low res signal.... so I think its worth it. Getting the high voltage stuff out of the Opti housing seems to improve its life expectancy.
Old Aug 4, 2004 | 03:17 PM
about how much does the LTCC cost?
Old Aug 4, 2004 | 08:13 PM
Dave88LX's Avatar
As has been stated, do a search on LTCC, you'll find all your information.
Search on Delteq too, it's another coil pack conversion. I bought that one...haven't installed it yet, but am very satisfied with customer servics thus far.
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
tdigger9899
Sep 7, 2015 10:56 AM
Pwilson59
Sep 3, 2015 08:47 PM
asilomar244
Jul 12, 2015 05:53 AM
