Code 24 need help.
I am getting my car dyno tuned on saturday and I have a code that keeps popping up the code is 33 on a 1993 Z28. The code is map sensor voltage high vacuum low. I have a CC306 cam and Lloyd Elliot heads on the car. Is there any reason that this code is setting. I am thinking it becuase of the low vacuum created by the cam. The map sensor is operating normally and was replaced. Anyone have this problem? Thanks.
Re: Code 33 need help.
If the rpms and vacuum get too low, the computer won't like the MAP reading. It is expecting to see readings in a certain range based on rpm and such. If the MAP gets too low, it will throw the code.
Deadbolt24
Jan 19, 2015 01:29 PM
Dec 23, 2014 07:52 AM
