Cooling fans not engaging-PLEASE HELP!!
Old Aug 4, 2004 | 12:32 PM
brians96Z's Avatar
I was driving my 96 Z last night, and the SES light came on. Now, since then, the car overheats when idling. (Fans are not kicking on) We pulled a code on it, but I can't remember the code #. Anyways....it was something like this-*Manufacture control circuit*, and it also said something about input and output. Anyone have any ideas as to the problem? I am wondering if it is just one of those big fuses. There are 2 I think for cooling fans. Any help would be great! Thanks in advance!
Old Aug 4, 2004 | 12:47 PM
Re: Cooling fans not engaging-PLEASE HELP!!
Check the fuses first and always post the number of the code if you can. Many code lists are generic and don't really tell you anything.
Old Aug 4, 2004 | 02:19 PM
brians96Z's Avatar
I'll try to find out the code number again, and post it. Do you have any idea how much those type of fuses cost? I know the rebular ones aren't bad, but I have never bought one of the *big black* fuses so to speak.
Old Aug 4, 2004 | 02:34 PM
Nah, you're thinking of the relays. Just check the fuses, first.
Old Aug 4, 2004 | 04:24 PM
brians96Z's Avatar
Shoebox, there are no fuses that relate to cooling fans. I chacked them all. There are 3 relays, though.
Old Aug 4, 2004 | 05:14 PM
disco192's Avatar
Check your ECT. Mine went out and it wouldnt kick on the fans. It is an $8 sensor that is right next to the waterpump. It tells the computer when to turn on the fans.
Old Aug 4, 2004 | 05:52 PM
brians96Z's Avatar
Ok, I got the problem fixed. It was a fuse. Can't get a much easier repair than that!
Old Aug 4, 2004 | 06:04 PM
I thought there were no fuses? If you are lucky, there won't be something intermittent causing it to blow.
Old Aug 4, 2004 | 07:56 PM
brians96Z's Avatar
Yeah Shoebox, you were right, there was a fuse. Well, that is the first time it has happened, hope something doesn't keep causing it. We'll see! Thanks guy or the help. It's great to have a place like this. It's like a free mechanic shop.
Noct
Jul 14, 2015 01:18 AM
Jmj93z28
Jul 8, 2015 10:01 PM
Jmj93z28
Jul 8, 2015 06:58 AM
warmeck
Jun 5, 2015 05:19 PM
Biggiebound
Apr 23, 2015 08:50 AM
