Does Tunercat show trouble codes?
Old Aug 3, 2004 | 06:17 PM
Wicked's Avatar
I did a scan on my car w/ it, but can't find anywhere on the program where it shows my trouble codes.. not sure if I did it wrong or what.
Thanks,
Jason
Old Aug 3, 2004 | 06:38 PM
Re: Does Tunercat show trouble codes?
Tunercat is a programmer, not a scan tool. No trouble codes.
Old Aug 3, 2004 | 06:47 PM
scoobysnax83's Avatar
Just for reference. Tuner cat has not developed a realtime program for the LT1 yet (meaning it cannot read the active or volatile memory). Or at least since last time I checked. It only reads and writes to the NVRAM (I'm a cisco man so that is the only way I can describe it) NVRAM being memory that is "hard written" therefore does not get erased when powered down. All trouble codes are stored in VRAM (Volatile memory) which is erased each time you power down (Pull the battery cable) That is why you can reset trouble codes by pulling power.
I believe (though am not familiar with) that Tunercat has developed realtime tuning for other types of vehicles. Which when implemented for our cars. Will be totally BAD ****.
Old Aug 3, 2004 | 07:06 PM
Wicked's Avatar
What can I use to scan the car? I guess Freescan doesn't work on OBD2 cars. I'd like something I can download onto the lap top so I can scan it tonight or tomorrow.
Old Aug 3, 2004 | 07:10 PM
1995 is not OBD2, i believe. I believe that you have an OBD2 connector but an OBD1 PCM. They make adapters. And Freescan (be this the situation) will work just fine.
Old Aug 3, 2004 | 07:20 PM
dreamer1q's Avatar
TTS datamaster gives 15 free runs. And it is the WHIP. I personally bought it because I liked it so much.
Old Aug 3, 2004 | 07:24 PM
Well, he's just going for a trouble code scanner and that's kind of overkill.
The one thing I really like about Datamaster is that you can reset the PCM and take it on a drive and actually see at what point the code kicks in. Makes it extremely easy to figure out the problem.
Old Aug 3, 2004 | 07:35 PM
If he has Tunercat, he is going to want something like TTS Datamaster to monitor the car and make logs. That's how you tell how your custom tuning is doing.
Old Aug 3, 2004 | 07:37 PM
Yea, yea yea....
DirtyDaveW
Dec 1, 2016 05:37 PM
armedtrigger
Feb 24, 2015 08:30 PM
David Dorris
Jan 17, 2015 08:10 PM
91Bird305
Aug 5, 2002 01:39 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
