Wires touching
Old Aug 3, 2004 | 06:53 PM
Cmr0z28's Avatar
Wires touching
Is it okay if the plug wires touch one another? I lost some of the looms when I put in my OTVC kit, and had to zip tie them together. Will this cause any interferences or anything like that?
Old Aug 3, 2004 | 06:59 PM
Steve in Seattle's Avatar
Re: Wires touching
space them out... especially the wires for cylinder 5 and 7.
Old Aug 4, 2004 | 12:48 PM
Cmr0z28's Avatar
Re: Wires touching
Are you sure? Why is this?
Old Aug 4, 2004 | 12:54 PM
Re: Wires touching
Probably because they are next to each other in the firing order. But, I would say that if the insulation is good on your plug wires, there should be no problem with them touching in a few places. What you have to watch out for is chafing that could cause the insulation to break down later and cause arcing. The factory commonly uses the small diameter corrugated tubing to keep the wires apart and from chafing. You might want to use some of that for insurance.
Old Aug 4, 2004 | 01:04 PM
Cmr0z28's Avatar
Re: Wires touching
Ok well I have the 1/3, 2/4, 5/7, and 6/8 cylinder plug wires ziptied together, and where they go down to the opti they're all ziptied together. If I put that tubing on all of the wires can I still ziptie them? Where can I get the tubing?
Thanks alot Rob.
*EDIT* forgot to mention, they're 8MM Taylor spiro pro universal wires mounted OTVC
Old Aug 4, 2004 | 02:48 PM
Re: Wires touching
The tubing can be purchased at about any parts place. No problem with zipping them together with the tubing on them.
Cam's maro
Mar 24, 2015 08:09 PM
94Z28LS1toLT1
Feb 26, 2015 07:47 AM
ModdedNerd
Dec 14, 2014 10:28 AM
Ryabut98
Sep 3, 2002 11:45 PM
sleeperZ96BT
Jul 24, 2002 11:28 AM
