Plug Wires!!!
Plug Wires!!!
Started to do Plug Wires on my 95 LT1, and was wondering if there are any hints on doing the passenger side with the network of pulleys that are in the way? Plus I ordered some MSD ignition wires( Super Conducters), and they gave me 10 wires, why is that?
Re: Plug Wires!!!
Remove the belt tensioner pulley assembly! It's only two easy to access bolts and it make pulling off the optispark wire ends ALOT easier. Also, I'm not sure why you have 10 wires, but you only need nine. I just redid mine and the spark plugs and then the ignition coil all thats there.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
grabbem88
Mar 18, 2015 01:25 PM
