Partial throttle sputtering?
Old Aug 4, 2004 | 11:08 PM
Mr.Whitey's Avatar
I have been having some problems with a sputtering at partial throttle. It doesn't always do it but other times it gets pretty bad. Most of the time it is noticable but to different degrees. If I got to WOT it seems to run fine. The problem may have some impact on WOT performance but I can't really feel anything and it seems to run smooth. The plugs are only about 3 mo. old and the wires and opti are about 1yr. old. The plugs look fine and the wires seem fine although I didn't remove the wires completely to check them out.
Any ideas what might cause this partial throttle sputtering?
Old Aug 20, 2004 | 09:03 AM
TransAmGT94's Avatar
Re: Partial throttle sputtering?
sounds like a bad opti. does your ses light come on from time to time when it is missing bad?
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
MDZ28
11
Sep 24, 2015 09:15 AM
tommalcolm
Sep 11, 2015 03:39 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
