LT1 Tuneup
Old Aug 4, 2004 | 10:48 AM
OutsiderIROC-Z's Avatar
LT1 Tuneup
I just bought a 95 Z28 and was wondering what I can do to tune it up. I know spark plugs are one of the obvious things but I am wondering what else. It has a K&N filter and the fuel filter was just changed. Any input would be appreciated. Thanks.
Old Aug 4, 2004 | 10:53 AM
andysc's Avatar
Re: LT1 Tuneup
When I buy a used car, I change all the fluids, as you do not know when and if they are even done, or if they used the cheapest fluid they could find. Next I replace the fuel filter, oil filter, and air filter. If it is a auto car, I replace the tranny filter when doing the fluid change. Then I will go over the car, and see what else it needs, but this should get you going for now.
Old Aug 4, 2004 | 11:02 AM
Red96Lt1's Avatar
Re: LT1 Tuneup
O2's, plug wires.
There was a thread on this like last week. Try to search for it.
Old Aug 4, 2004 | 11:56 AM
Re: LT1 Tuneup
Originally Posted by Red96Lt1
O2's, plug wires.
Sorry, I am new to this board......
I got the car from my best friend so I know the past 3 year's history on the car.
The 02 sensors were replaced last fall. The water pump, fuel pump and fuel filter have been changed last year as well. I have already changed the oil and filter, the car has a K&N that was installed maybe 6 months ago. Next on the list is the tranny fluid and filter along with the differential fluid.
Plugs and wires will need to be changed as well. I wasn't sure how the plug wires were on the LT1 with Opti-Spark.
Old Aug 4, 2004 | 12:39 PM
Re: LT1 Tuneup
The plugs and wires will be an adventure. It will take some time and patience.
Old Aug 4, 2004 | 12:57 PM
LT1Squirrel's Avatar
Re: LT1 Tuneup
PCV valve, check egr crap , unhook the 02's and seafoam da bish , if the coil is stock i suggest throwing a replacement in there, im runnin the MSD Blaster, good cheap coil
Old Aug 4, 2004 | 02:19 PM
Re: LT1 Tuneup
That is what I have been told!! What kind of ends are on the wires on the distributor end. HEI or Points style because I will probable make me a set of wires. I have had good luck with the Moroso wires on my Firebird.
What do y'all recommend for plugs and wires? The car is stock except for K&N filter.
Old Aug 4, 2004 | 02:43 PM
Will84's Avatar
Re: LT1 Tuneup
Most people will agree that you should go with Taylor OVC wires (Over Valve Cover). That will make things a helluva lot easier. Do a search about the plugs... I'm not sure what everyone prefers.
Old Aug 4, 2004 | 02:55 PM
Re: LT1 Tuneup
plugs can be grouped under the same debate 'which oil is better'...peopole use: autolites, bosch, ngk, acdelco, denso, champion, etc etc....its just best to pick a plug youve had good experiences with
im using bosch plats, the regular 2 buck ones
Old Aug 4, 2004 | 03:05 PM
My Red 93Z-28's Avatar
Re: LT1 Tuneup
I have the Accel Extreme 9000 plug wire and they work really well. As long as you route them carefully you don't have to go with the OTVC kit, but it is a matter of preference. I have never seen the OTVC kit, but when I routed mine it took two people and 3-4 hours, and a lot of double and triple-checking from all different angles. I've had them on for over 3.5 months and no problems whatsoever.
Old Aug 4, 2004 | 03:10 PM
Red96Lt1's Avatar
Re: LT1 Tuneup
I love my OTVC, not quite sure how well they would work on stock manifolds, since they come up off of the heads. Looks like they would get in the way.
Old Aug 4, 2004 | 03:37 PM
Will84's Avatar
Re: LT1 Tuneup
Good point. I have headers... so I have no idea how well they'll work with stock manifolds.
Old Aug 4, 2004 | 03:39 PM
Re: LT1 Tuneup
That is one thing I do NOT plan on installing in the distant future is headers, not on this car.....
Old Aug 4, 2004 | 06:38 PM
Re: LT1 Tuneup
Mind if I ask why?
Old Aug 4, 2004 | 06:56 PM
BackNBlack's Avatar
Re: LT1 Tuneup
I just took my OVC's off and installed stock type wires, burned up a few Taylors on the manifolds after a while... I have stock manifolds still... I might try the OVC's again after I get my longtubes on. I went with AC Delco wires and plugs.
