Highest Mileage when doing cam swap
Old Aug 3, 2004 | 07:56 PM
vin1382's Avatar
Hmm, after reading some threads about spun bearings and what not, I figured I'd like to see what type of risk im up against when I go for a cam swap.
I have 84K miles on my 93 lt1, and am gonna do a hotcam kit in the winter when the driving season is over. This car has been babied and garaged most of its life, and never really driven hard(not sure if that matters!).
Anyway, Im curious as to who here has done a successful cam swap with the highest mileage? Did you eventually spin a bearing? Still going strong? How high are you revving?
Old Aug 3, 2004 | 08:14 PM
kcz28's Avatar
Re: Highest Mileage when doing cam swap
I installed the hotcam kit with 138,000 miles on the clock.
Haven't had any problems so far. Drove the car for about 700 miles
to get it broken in. The pcm was tuned by pcmforless, so i'm
reving at about 6,200 rpms.
Old Aug 3, 2004 | 08:22 PM
grygst76's Avatar
Did mine with 119,000 miles, no problems yet spinning to 6800
Old Aug 3, 2004 | 08:35 PM
smokindastangs's Avatar
I think you will be ok....I have revved my 90k to 7k several times and a hotcam isn't that big; so yeah, go for it.
Old Aug 3, 2004 | 09:32 PM
vin1382's Avatar
Nice, that is encouraging . This is the stuff i am hoping to hear. I am gonna do it anyway...but just wanted to see what my odds were. Im a gamblin man. I figure if its done right, and if the engine is in good shape regardless of miles, it wouldn't be a problem.
Old Aug 3, 2004 | 09:34 PM
vin1382's Avatar
The hot cam is still making power up at 6800?? . Where does it signifigantly fall off generally?
Old Aug 3, 2004 | 10:04 PM
before 6800 :-)
Old Aug 3, 2004 | 10:15 PM
vin1382's Avatar
Originally Posted by smokindastangs
before 6800 :-)
. i was gonna say.. i figure the best shift points would be between 6200-6400. would be nice to have a screaming small block churning up around 7K
Old Aug 3, 2004 | 11:48 PM
disco192's Avatar
mine spins to 7k
Old Aug 4, 2004 | 05:25 AM
jkipp84's Avatar
I threw the XE in @ 103k miles. Never had a problem. Some do run into issues with much less miles though, they just haven't posted.
Old Aug 4, 2004 | 05:29 AM
grygst76's Avatar
I have the 306 cam, not Hotcam.
Old Aug 4, 2004 | 07:41 AM
SantaCruz163's Avatar
For you heads/cam guys. When did your installation did you follow Shoebox's guide for it, and was it very accurate? When I do mine I plan on using that as well as a Haynes manual. I am mechanically inclined, me and 1 friend changed the clutch in my V6 FWD Maxima in 11 hours and that job was a B!TCH so I don't think this will be as hard.
Old Aug 4, 2004 | 08:36 AM
reuter's Avatar
130,000 miles on my car and it turned over 411rwhp/372rwtq after doing my heads/cam install. it made that power at 6,000RPMs since i had an overtightened rocker causing the valves to float after that.
when you install the heads id yank the motor. i did. replaced all the seals, gaskets etc. i could get my hand on and damn am i glad i did it out of the car. got to paint the block up, it looks good. plus you can check for any play in any of your rod and main bolts. it's WAY easier out of the car. you should definitely consider it. i dont think i'd feel comfortable torquing head bolts in the car. stuff is a little too critical.
HectorM52
Jul 30, 2017 11:46 AM
chuyz28
Feb 19, 2015 12:50 AM
chuyz28
Jan 15, 2015 04:14 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
chuyz28
Nov 25, 2014 11:14 PM
