Lifter Guides
Lifter Guides
Ok so about a week ago i had some trouble getting my rockers to lock correctly and a few completely backed out on me to the point where the rockers and pushrod werent in place anymore. I fixed that and noticed i was still getting alot of knock retard.
So today i put some threadlocker in my rocker studs and when i was putting the pushrods back in the lifter guide was loose on the #5 cylinder. I could move it with the pushrod. I assume it came loose when the rocker wasnt on the pushrod, but i dont know.
Im assuming i have to pull the manifold and set them back under the spider, but could i have done any damage to the lifters or the block? I just rebuilt the top end of the motor, so it wont take long this time... just a headache.
THX,
Stu
THX,
Stu
Re: Lifter Guides
well.... took the intake off and checked everything. As i suspected the spider got bent up quite a bit and the guide was completely loose. I bent the spider back in place and checked out the lifters. From what i could tell, the lifters looked in good shape.
I got a helpful hint from a local speed shop too. I was having trouble keeping the polylocks from backing out and he told me to take off the rocker studs and put them on a grinder and grind the tops completely flat. That will give the polylocks a clean place to lock on to.
Then i set the lash while the engine was running. By far the best way to do it IMO.
Now she screams up to 6800 rpm. Im still getting about 1-3* of Knock retard. Is that normal with comp-r lifters, RR, and no LT4 KM??? Most of the KR goes away once i hit WOT though.
NewsBot
Sep 30, 2015 04:20 PM
NewsBot
Sep 14, 2015 09:20 AM
