Attn: Experts need help asap (shoebox)
Old Aug 6, 2004 | 12:51 PM
ollie-99's Avatar
i run the car for id say 10 min or more and @ lights it will start to stall and shut off then is a pain in the **** to start..
im starting to think fuel pump?
cuz when this aint happenin it does have enough go as it did before...
ALSO
when i am havin the issue it will just lag and seems as if it aint gettin enough juice..
So far.. ive replaced: lifters,opti, coil, battery
Could it be a clogged fuel filter i did it like 50k km ago??? it only happens after a few minutes of drivin its pissin me off like 10+ minutes
maf is plugged in
i tried unpluggin it and same issue
so please gimmie ur suggestions
thanks
-Oliver
Old Aug 6, 2004 | 12:55 PM
Re: Attn: Experts need help asap (shoebox)
Check fuel pressure to rule it out. I see you have removed the EGR. Make sure your plate has the passages sealed up.
Old Aug 6, 2004 | 01:01 PM
ollie-99's Avatar
do i connect a fuel pressure guage to the regulator? or where
Old Aug 6, 2004 | 01:04 PM
ollie-99's Avatar
egr plates are on and not leaking
Devinfoote87
Sep 4, 2015 05:52 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
gelbza
Jul 12, 2015 08:10 AM
asilomar244
Jul 12, 2015 05:53 AM
