Whats causing the rich condition?
Old Aug 3, 2004 | 10:19 PM
Myxtreme1's Avatar
Well the more annoying part of it lately is a gassy smell from the exhaust. At times it almost seems boggy from dumping too much gas. I have no codes. New o2's. I need to get it scanned again anyway I guess. Maybe I'll replace the EGR just for the heck of it. Seems to be the original anyway. Anyone have any other suggestions?
Old Aug 4, 2004 | 11:42 AM
Re: Whats causing the rich condition?
Do you still have a cat in place, and working?
The most frequent causes of "rich" conditions are misfires, exhaust leaks before the O2 sensors, and faulty O2 sensors and/or wiring, extensions, etc.
Old Aug 4, 2004 | 03:56 PM
Myxtreme1's Avatar
The cat is gutted and I haven't been able to really tell if I have an exhaust leak in the header area.
Old Aug 4, 2004 | 04:25 PM
Originally Posted by Myxtreme1
The cat is gutted.....
That explains it. You need a wideband exhaust check, or a look at the long-term fuel corrections to see if your perceptions are correct.
Old Aug 4, 2004 | 04:51 PM
Rezhalo3's Avatar
Do these cars have rear O2's? I know that if you remove the cats or gut them then the rear O2's will freak out when they read the "seemingly" out of whack conditions and cause several problems. I would not think that the O2's would read a lean condition and add fuel.
BUT the gutted Cats are flowing freely and the gasses that should be burned in the cats are not being burned. If they are not being burned then they are being released and then you get the fuel smell.
I could very well be wrong but I thought I would add my .02 .
Richie
Old Aug 4, 2004 | 09:00 PM
Myxtreme1's Avatar
No, no rear 02 on mine. That's why I ruled out the cat being the problem before.
Old Aug 5, 2004 | 09:55 AM
Only the OBD-II cars (96-97) have after-cat O2 sensors. And, when you get a code for an after-cat sensor, it won't cause "out of whack conditions" and problems. Just lights the SES light to tell you your cats aren't working.
Lacking a cat, the level of the unburned hydrocarbons in the exhaust increase significantly.... it smells worse, even when its running right. I run no cats on my track setup, and even though the tune is dead-nuts on and verified with a wide-band, the fumes from the C-16 it idle will leave your eyes watering.
You need to check for exhaust leaks and/or misfires. A scan would tell you if you are having a "false lean" condition, that is causing the long term fuel corrections to pour in fuel the engine doesn't need.
Old Aug 5, 2004 | 05:37 PM
Myxtreme1's Avatar
I will have to get it scanned again for sure. I just can't find any exhasut leaks. I have a set of fel-pro's that I'm gonna put in though. Should I buy a hi-flow cat?
grabbem88
Apr 16, 2015 06:57 PM
ad356
Apr 11, 2015 10:30 PM
Magenta_Hearts
Mar 22, 2015 03:36 PM
grabbem88
Mar 18, 2015 01:25 PM
Iamherefornow
Jan 26, 2015 04:57 PM
