Need help picking camshaft
Old Aug 4, 2004 | 12:59 PM
Dave '97 Z28 M6's Avatar
To make a long story short, my LT1 recently had a head gasket failure. No internal damage, but since it has 125,000 miles of fun under it, I figured now was a good time to do what I really want to do with the engine.
I'm having a 383 built, with the following specs:
cast crank (Eagle or Scat)
forged pistons, 10.5-11:1
stock intake and heads, both ported (gasket matched)
52mm TB
shortie headers (Edel.)
CAI
As you can see, this is not too exotic a build-up. The car is driven daily (well, not at the moment ). My conservative goal is roughly 400 (crank) hp in a package that will be civilized. I'd like a cam that will give me good power across a wide band, a little bit of lope at idle, but reasonable enough to live with every day. I don't want something that will barely idle or surges while cruising in 6th.
Basically..... as much power as I can get out of this package without sacrificing too much drivability. I'm willing to go off-the-shelf or custom ground for the cam, BTW. Just having a little trouble translating all the #'s into real-world info.
Thanks for any input.
---Dave
Old Aug 4, 2004 | 01:07 PM
Camaro_Maniac63's Avatar
Re: Need help picking camshaft
If you are willing to go custom, contact Bret with Bauer Racing Engines. He should be able to get you a custom cam matched to the rest of your combo.
If you want off-the shelf, I would try the GM847. Actually, I have almost the same combo and that is what I will be using.
Old Aug 4, 2004 | 01:39 PM
Valkyn71's Avatar
I dont think i would run a 383 with stock heads.
If you only wanted around 400 flywheel horse power you could slap in an LT4 hotcam kit for $700 bucks and be all set.
If you were willing to get some heads that will support your 383, having 400RWHP would be a very attainable and even conservative goal on a streetable setup.
Old Aug 4, 2004 | 03:30 PM
STAR's Avatar
If your goal is only 400 flywheel hp than no need for a custom cam. Just pick an off the shelf grind like the hot cam or GM846 and you'll reach your goal. These cams in a 383ci motor will idle and drive almost like stock.
Old Aug 5, 2004 | 01:21 AM
Thanks for the help, guys.
I've been thinking of the GM847 & hotcam. Could anyone compare the 2 of them for me?
Valkyn71: I agree that a good set of aftermarket or heavily reworked heads would be preferable... maybe I'll be doing that down the road.
Any more opinions out there?
Also, I have not decided yet on RR's vs. stamped pieces. I know that stamped rockers aren't cool, but I'm not sure that rollers are worth the $ for this build-up.
Old Aug 5, 2004 | 06:47 AM
1racerdude's Avatar
Dave
Do you have any head flow numbers.If you do I will run it on my set up and see what it comes up with for cam number's.
Old Aug 5, 2004 | 10:00 AM
Thanks for the offer, but I don't have any #'s on the heads, since they've just gone to the machine shop, along with the block.
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
1994formy
Wheels and Tires
Sep 28, 2015 01:11 PM
Daluchman1974
Sep 11, 2015 06:12 AM
