Stock cam rpm limit?
Old Aug 4, 2004 | 09:56 AM
texlurch's Avatar
What is the maximum that you rev your stock LT1 cam? And what happens when you reach the limit? Does the motor just go flat and not want to go anymore?
This is regardless of any RPM/PCM shut off...
Just curious?
Old Aug 4, 2004 | 10:54 AM
383Z4ME's Avatar
Re: Stock cam rpm limit?
Using stock heads and a little after market cam upgrade my engine still fell on its face around 5400. You can set shift points a little higher, with LT1edit for instance, and feel it sort of float wen it revs past peak power. Horsepower curve must go right off a cliff. I think the heads are the limiting factor.
rideordie
Nov 5, 2019 04:52 PM
Noer
Feb 28, 2015 11:29 AM
blac94Z
Feb 18, 2015 11:36 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
