What size is thep plastic tool needed to disconnect fuel lines???
Old Aug 4, 2004 | 07:08 PM
trans9_5am's Avatar
i think i have a few different sizes just dont know which one to use and i cant get any of then to work. do you just push the tool up and pull the line off or do you kind of squeez them both together and then pull the line off? Need help NOW.
Brandon
Old Aug 4, 2004 | 07:27 PM
bdc95ta's Avatar
Re: What size is thep plastic tool needed to disconnect fuel lines???
There's two diff. sizes can't remember them right now. You slide the thing on then push it all the way in and push the fuel line towards it then pull it off.
There are metal clips holding on the fuel lines the disconnectors just push them up so you can slide it off. hth
-b
Old Aug 4, 2004 | 08:08 PM
Dave88LX's Avatar
Just go to your local automotive store and get the assorted sized plastic ones that come on a little plastic rail... It shouldn't be more than a few dollars for the set.
Old Aug 4, 2004 | 09:47 PM
3/8 for the pressure line and 5/16 for the return line.
Old Aug 5, 2004 | 07:17 AM
trans9_5am's Avatar
Thanks guys, i got them off. Werent really that hard i just think i was using the wrong size. Oh well, thanks for the help.
Brandon
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
