LT4 head gaskets
Old Aug 4, 2004 | 12:13 PM
JamesNobles's Avatar
LT4 head gaskets
OK Im gonna need some new gaskets once I pull of my heads for porting and polishing...(94 LT1) I have heard that getting some LT4 head gaskets will lower/raise your compression...my question is it true and is it worth it??
james
Old Aug 4, 2004 | 02:55 PM
Re: LT4 head gaskets
TTT? Anyone heard of this before?
Old Aug 4, 2004 | 06:13 PM
So no one in here knows anything about this?
Old Aug 4, 2004 | 06:39 PM
Spinner's Avatar
LT4 engines used the same gaskets as lt1 engines.
Impala gaskets are thinner, and raise compression, NOT lt4 gaskets
Old Aug 4, 2004 | 06:43 PM
Well either way, would it make a difference and would it be worth doing? And on Thunderracing.com, they say that LT1 gasket is .050 and LT4 is .043? So thats what I was basing my numbers off of...would it be worth it?
Old Aug 4, 2004 | 11:49 PM
Curt (pres AAMC & ZAA)'s Avatar
Stock LT1 gaskets are .049", Felpro are .039" and the Imp gaskets are .029".
Old Aug 5, 2004 | 04:50 AM
anaik's Avatar
You are correct, there is an LT4 head gasket. GM #12551488, and it is .043. Since going from a stock .049 to an Impy .029 gives you about a half a point in compression, going to the .043 won't raise it much.
Old Aug 5, 2004 | 05:14 PM
Sunsceamer's Avatar
well half a point meaning 10.4 to now a 10.5 or what? How much can you take of with thinnier gaskets and or heads before have to change push rods?
Old Aug 5, 2004 | 08:25 PM
Spinner's Avatar
10.4 to 10.9
I'm still running stock length rods, but i know they're not ideal. I'll probably go to 7.150" rods soon
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
