30 lb injectors
Old Aug 3, 2004 | 08:08 PM
chrism400's Avatar
30 lb injectors
If 30 lb injectors are installed, do you have to reprogram the pcm or does the computer just reduce the duty cycle on its own? I have a 50 dry shot and would like to go to a 75 just for grins .
Old Aug 3, 2004 | 08:11 PM
Spinner's Avatar
Re: 30 lb injectors
Going to need it programmed.
Old Aug 3, 2004 | 11:27 PM
chrism400's Avatar
Re: 30 lb injectors
Can Brian Herter do it at PCMforless?
Old Aug 3, 2004 | 11:37 PM
Loadre's Avatar
Re: 30 lb injectors
Yes. I would recommend him.
Old Aug 4, 2004 | 12:02 AM
S.J.S.'s Avatar
Re: 30 lb injectors
I went through Bryan and my car totally rebuilt fired up on a touch of the ignition and has run perfect since.
Old Aug 4, 2004 | 11:08 AM
Re: 30 lb injectors
How does your dry kit "add" the fuel required for the nitrous? Most of them increase the fuel pressure to get the extra flow. You would just need to bump the fuel pressure higher to increase the flow from what is required for the 50-shot, so you could run a 75-shot. You typically don't change injectors, you alter the fuel pressure, using the method provided in your kit.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
