How hig can you rev a stock LT1
Re: How hig can you rev a stock LT1
Be sure to specify if you are talking about the tach reading or the actual engine speed. My car when stock ran best with the tach needle at 6000... this was in reality 5800. Most that I have seen are reading approx. 200 rpm higher.
If you rev, without a load, dont go above 4750 on your tach reading. If you do so, you will start knocking your engine around. When you have a load on your engine (ie moving in gear) then you can hit 6000 if you want to.
oldschool
Feb 9, 2016 09:21 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
