Cam or Spray?
Old Feb 19, 2005 | 03:23 PM
87transam383tpi's Avatar
Cam or Spray?
Just wondering what everybody thinks, camshaft 239/248 115LSA .577/.6 camshaft of 100hp shot of spray? any dyno numbers over stock cam to a bigger one like that? thanks
Josh
Old Feb 19, 2005 | 03:53 PM
ChvyCruzen's Avatar
Re: Cam or Spray?
IMO if you are going to mod your LT1 you should cam it. Nitrous requires refills and I think its a waste. If you are going for a cam as big as you just said, you should make sure your top end matches up with that cam to produce its potential HP. Otherwise, everything will be mis-matched and wont run as effectively. Sure it will sound sweet, but you cant just slap something on and expect to see all the gain from that.
Old Feb 19, 2005 | 04:20 PM
Re: Cam or Spray?
ya heads are already done and so is the intake. just trying to decide how to spend the next $750 or so. thanks
Josh
Old Feb 19, 2005 | 06:52 PM
silverz28's Avatar
Re: Cam or Spray?
both
Old Feb 19, 2005 | 09:17 PM
Flyin_Z28's Avatar
Re: Cam or Spray?
Originally Posted by silverz28
both
I second that. Spray when you really wanna have some fun!!
Old Feb 20, 2005 | 11:20 AM
chrism400's Avatar
Re: Cam or Spray?
When my car was running 13.40's, a 75 dry shot put me at 12.25 @ 112. That was with a stock cam and no headers. That cam you are thinking about is way too big!!!!!!! These roller cams don't need near the same durations that flat tappet hydraulics need to make power. I now run nearly the same numbers NA with a fairly mild cam and basically no stall.
Old Feb 20, 2005 | 11:31 AM
ChvyCruzen's Avatar
Re: Cam or Spray?
Chrism is right. The roller cams dont need near the same durations as the flat tappets. The cam that you are asking for sounds like its powerband is around 2600-7000 or higher. The lift as well as the duration of the cam sounds like an extremely aggressive cam, maybe too aggressive. Are you a daily driver? I wouldnt suggest this cam on a daily driver.
Old Feb 20, 2005 | 11:34 AM
oneslowz28's Avatar
Re: Cam or Spray?
if you have head work and intake work done then get the cam becuse if you have ported the intake and heads your still chocking the engine with the stock cam it seems like the best cam for the lt1 is the comp cams cc306. atleast thats the general cecious.
rideordie
Nov 5, 2019 04:52 PM
Klypto
Mar 23, 2016 09:05 AM
IgorT.455/406
Mar 12, 2015 03:39 AM
Fatdog2
Feb 13, 2015 08:19 PM
