Today's Dyno Numbers
Old Feb 19, 2005 | 04:58 PM
whontime's Avatar
I went to a local dyno day earlier today. Here are the numbers.
1994 M6 Z28
LE Heads, 2.02/1.60 valves, Combo 612 Springs
227/233 XE camshaft, 1.6 Pro Mags
Jet Hot LT's, True Duals
Moroso CAI
Moser 12 Bolt, 4.56 gears
Stock Bottom End
Motor Pull:
347hp, 328tq. The numbers are down from my earlier pull of 351hp/347tq, but I attribute the loss to the dual exhaust which changed my AF ratio to 11.9 on today's pull.
Nitrous Pull: 175hp Nitrous Works Plate
497hp, 510tq
The AF ratio was a nice 12.9 all the way through the pull.
All dyno numbers are SAE corrected.
Old Feb 19, 2005 | 06:31 PM
Munson's Avatar
Re: Today's Dyno Numbers
Nice, Im guessing the reason your N/a numbers are kindof low is because the cam is for nitrous?
Old Feb 19, 2005 | 06:39 PM
Young1Z's Avatar
nice.
Old Feb 20, 2005 | 02:44 AM
whontime's Avatar
It's a NA camshaft. It is the 227/233, 560/569 XE from Combo Motorsports. The NA numbers are kinda low, but I think I could have squeezed around 360rwph out of it if it were leaned out to around 13.1 instead of the 11.9 that we ran at today. Also, I don't have an electric water pump, crank pulley or any of the little stuff that makes those last few ponies. I figure if everything was tuned for a NA pull it would top out around 360/345. However, I always run nitrous at the track so we have it set up for nitrous.
Old Feb 20, 2005 | 11:14 AM
chrism400's Avatar
Have you ever run this beast NA and on the jug?
Old Feb 20, 2005 | 11:45 AM
Munson's Avatar
did lloyd fully port those heads?
Old Feb 20, 2005 | 05:21 PM
whontime's Avatar
Lloyd did these heads back before he had any set "stages" or cam packages so I can't really say. The flow numbers look like his full port stuff though. I haven't had a chance to run the setup yet, but the tracks around here are starting to open back up so it shouldn't be long.
Old Feb 20, 2005 | 06:10 PM
turbo_Z's Avatar
Id expect at least 380 NA with that combo of parts. How much hp does a 12 bolt normaly eat up?
Old Feb 20, 2005 | 06:16 PM
chrism400's Avatar
What rpm did you have peak hp and torque?
Old Feb 20, 2005 | 06:36 PM
whontime's Avatar
Yeah, that is what I would have liked to see, but the most the car has made with the 12 bolt is 356hp/347tq which was on a different day and before the dual exhaust setup was installed. This combo is probably good for around 365hp is everything is just right. I don't see it making 380hp for me though. I think the "real world" track numbers will be nice though, especially with the nitrous.
EDIT: The 12 bolt will eat up around 10-15 hp in most instances.
Old Feb 20, 2005 | 06:43 PM
whontime's Avatar
Also, the peak hp looks to be just before 5500 rpm and we spun it up to around 6500 rpm.
HarleyZ28
Oct 5, 2015 06:23 AM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
ChrisFrez
Mar 1, 2015 01:33 PM
StngStlkr
Sep 6, 2002 05:47 PM
Joe Brodman
Jul 24, 2002 05:24 AM
