What type of timing chain do I need for my setup???
Old Feb 18, 2005 | 10:34 PM
texasTA's Avatar
I am building a solid roller LT4 383 motor that will have a 300-350 shot being sprayed on top of it.
Whay brand/type of timing chain would you guys recommend that I use with this setup?
I was thinking a double roller with electric waterpump. But I am open to suggestions.
Old Feb 18, 2005 | 10:38 PM
Re: What type of timing chain do I need for my setup???
You must give a year of engine if you want accurate advice. It makes a big difference.
Old Feb 18, 2005 | 10:39 PM
texasTA's Avatar
Sorry about that Rob. It is a 94 Trans Am. I was already thinking of switching to the vented opti, but I might go dynaspark, so I don't know if that matters either.
Old Feb 18, 2005 | 10:40 PM
Seal's Avatar
also is this a street car, or track?
I personally wouldnt go with a elec wp/double roller if it was a street car
i got a 355 turbo and have a gm extreme timing chain set
Old Feb 18, 2005 | 11:27 PM
Make a short sig.
For cars with the non-vented opti, you are pretty much stuck with the stock cam gear and timing set or a very expensive aftermaket gear set.
Old Feb 19, 2005 | 02:13 AM
Heatmaker's Avatar
Advanced Member
I'd reccomend an Adamantium timing chain... they are hard to find but I think summit sells them. Strongest metal around...unbreakable they say.
Old Feb 20, 2005 | 03:07 PM
texasTA's Avatar
The car is going to have to do a little daily driving, not much but some. I am also driving 4000 miles this summer for the Hot Rod Power Tour.
Here is the short sig Shoebox:
383 (callies, JE FSR, Clevite, hellfires)
fully ported LT4 heads/intake by Jordon Musser
58mm TB
solid roller camshaft
300-350 direct port NX setup
a4 with 3600 stall
12bolt
Originally Posted by shoebox
Make a short sig.
Old Feb 20, 2005 | 04:18 PM
You must be referring to the Wolverine set.
Old Feb 20, 2005 | 07:50 PM
Heatmaker's Avatar
Advanced Member
Lol's .. I actually had a guy calling around looking for a set of adimantium Pistons once... I'll never forget that day.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
