Is this true about heads???
I have heard you can tkae traditional SBC heads that flow better than lT1 heads and have them converted over to Reverse Flow cooling for better air flow. Can this be done? I have heard about this but i am not for sure.
Guest
Posts: n/a
Re: Is this true about heads???
Yes, it can be done and there have been many guys that have done it. Do a search on here and you will find several threads about the subject and I believe that some actually list some prices. I was going to go this route until I got my AFR's.
The LT1 head is a very good head, better than the double-hump or what ever old timers love to talk about. Even better is the LT4 head.
The mis-conception you have is people take racing traditional SBC heads and convert them...like some Pro-Actions.
The only reason I would go to a traditional SBC head would be to change the angle. You can get stout performance with AFR heads already setup for reverse cooling.
You would be nuts to take any GM casting pre-LT1 and convert them IMO.
hmmm , how would a sbc work with lt1 heads if they flow that much better than sbc heads, ...a little reverse engineering.
i put absolutely no thought into this , just incase it sounds rediculous
Guest
Posts: n/a
Posted by: Z28SORR
This makes no sense!
I haven't seen anything AFR makes for an LT-1 that will flow in the 330-340CFM range like a converted set of Pro action's.If they say they do their flow bench is very "happy" in it's readings.
you guys are nutz that dont make no sense.
It is not very hard to convert older style heads to lt1. all you have to do is seal up the coolant passages that would go through the old style intake. Then drill and tap two holes in the back of the heads for the crossover tube. Then the bolt pattern is deffernt for the intake. You have to drill a few more holes in the intake to fit it on the head. Thats it your done. The AFR's for gen 2 are the same as gen1 but cost 2 times more. I would go convert their gen 1 to gen 2 for the best bang for the buck.
Or if you have 396+ with a huge cam Jegs makes a pair that out flows AFR and any other company i've ever heard of. Those would make some power on a gen 2.
Originally Posted by Red_94Formula
Those pro actions wont work on anything smaller then a 396 with huge cam. Thats why they have 230cc or bigger intake runners
Formula,
I wish it was that simple to change the heads over. That's the jist of it, but you still have oil drain backs that you have to put in there and it's a good idea that all of these things don't leak, you don't want oil in the coolant.
230cc is not that big of a runner size, It would actually work well on a street 383 if the motor was made for that. Then again port shape, length, cross section are all more important than port volume.
Basically unless you are going really crazy you don't need a set of converted heads. A good set of 300cfm 23 deg heads can support 600hp you just have to match the combination up well.
If you are going to do it, 18 deg or a race casting like a SB2 is the way to go. RacerDude has a set of 23 deg heads that were converted, he had West Coast Cylinder Heads do them and talking to the owner it's not his favorite job to convert them over.
Bret
Bret
Originally Posted by 1racerdude
That must be why I am running them on a 383,is because they won't work.They have 247CC runners and runner CC's can't be compaire due to length,ya need the cross section to know.
Originally Posted by SStrokerAce
You beat me too it man!
I don't think Richard would do another conversion for $1500.00 on top of the port work. They were done Right though.
