LT1 Engine Bolts
Old Feb 20, 2005 | 10:32 AM
TransAm9585's Avatar
LT1 Engine Bolts
Iv searched and couldnt come up with an answer for the following questions.
I have to assemble a 1995 LT1 and i need a ton of bolts and hardware. I need intake manifold bolts as well as all the bolts for the accessories. Anyone know where i can get these? Thanks.
Old Feb 20, 2005 | 12:22 PM
Re: LT1 Engine Bolts
For specialized bolts, it looks like a trip to the dealer. A lot of common assembly bolts can be gotten from companies like ARP.
Old Feb 20, 2005 | 01:52 PM
Dave88LX's Avatar
Fear not! I used this kit on my LT1, I've got nothing but great things to say.
http://alloyboltz.com/cgi-bin/alzsto...talogno=A-5438
LT-1 Allen Bolt Engine Kit
A-5438
Dress Up Your Small Block Chevy LT-1 Tuned Port Engine With This 162 Piece Stainless Steel Allen Bolt TPI Engine Dress Up Kit. This Kit Is Guaranteed To Fit Stock Engines!
These Allen Bolts Are For The Entire Engine From The Top Plate To The Oil Pan. The kit also includes Mil Spec Stainless AN flat washers where they belong which will fit in the tightest spots. This kit consists of Allen bolts for the following:
Top plate, Center bolt valve covers, Timing cover, Thermostat Housing, Fuel Rails, Throttle Body, Throttle Bracket, Oil Pan, Intake to Heads including studs, Water Pump, Map Sensor, and an EGR Stud Kit.
This item is In-Stock
Price: $71.00
Old Feb 20, 2005 | 03:29 PM
slverbullet's Avatar
hey, i was just doing another search on bolt kits. try ebay. heres a couple different ones. the allen set and a chevy bowtie set.
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
edit: found this set on yahoo: http://www.boltlocker.com/lt1-4.htm. only $40 for the allen set.
Old Feb 20, 2005 | 07:44 PM
Just remembered that i have the Mitchell catalog with all the numbers for the parts i need lol. So ill order one of these kits then go through someone at a dealer because i have the stock numbers now thanks for all the help guys and to the links. Ill probably go with just the regular stainless in the first link.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
ddr698
Jan 9, 2015 10:05 AM
Jul 4, 2005 05:00 PM
