Low Coolant Light
Old Feb 23, 2005 | 03:05 AM
nin97's Avatar
Low Coolant Light
my low coolant light keeps coming on...but the coolant is fine its full pretty much...and it's clean too?
could it be the sensor? if yes...where is the sensor located? and how much is it to replace?
Old Feb 23, 2005 | 04:13 AM
EaC95Z28's Avatar
Re: Low Coolant Light
low coolant sensor. part number on shoe boxes site. grey square box about 4-5 inches below radiator neck on passenger side. cant miss it. 35-40 bucks is cost. do it urself takes about 10 minutes. including draining refilling radiator fluid.
Old Feb 23, 2005 | 10:01 AM
Camaro97USAF's Avatar
Or just unplug it. Thats what I did, no more light,
Old Feb 23, 2005 | 01:03 PM
ShelbyZ28's Avatar
I did the same a few weeks ago with no problems. I wouldn't spend the money to replace it as it will eventually fail again. Someone correct me if I'm wrong, but I think I've read on this site GM stopped using them in 01 or 02 on our cars because they realized they were junk.
Old Feb 24, 2005 | 09:02 PM
green93formula's Avatar
My 93 Formula does the same. I checked my fluids, and everything was pretty much topped up. It sounds to be a little common
Old Feb 24, 2005 | 10:55 PM
Bawls's Avatar
Correct LS1's dont even use em. I've just unplugged mine and didnt worry about it.
Old Feb 26, 2005 | 03:11 PM
nin97's Avatar
awesome! thanks guys
calaban
May 18, 2020 06:43 PM
silvermansteve
Mar 4, 2015 05:02 PM
MattFick
Feb 15, 2015 10:16 PM
Jan 23, 2015 01:13 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
