CompCams Magnum vs. Pro-Magnum Rockers
Old Feb 22, 2005 | 08:58 AM
Jeff Nichols's Avatar
Question CompCams Magnum vs. Pro-Magnum Rockers
As the title suggests, can anyone give some thoughts/ideas/opinions on whether the CompCams Magnum rockers would be a good upgrade? I know many people here run the Pro-Magnum, but right now price is an issue. Also, with 127K on the motor, I figure any little bit will help with power until I'm ready (forced) to rebuild.
Thanks.
Jeff Nichols
95Z
Old Feb 22, 2005 | 10:03 AM
1-bad-z28's Avatar
Re: CompCams Magnum vs. Pro-Magnum Rockers
aren't they the same thing? Comp Pro Magnums?
Old Feb 22, 2005 | 10:28 AM
No, the Magnum rockers look like the stockers, except they have a roller tip. THe Pro-Magnums have the roller tip as well as needle bearing truinions (and I think they are stronger chromemoly steel).
Old Feb 22, 2005 | 11:22 AM
1-bad-z28's Avatar
ohhh....ok
Old Feb 22, 2005 | 03:20 PM
IMO, I would not bother with roller tipped rockers. The full roller rockers give the most benefit. I think if you compare the price of the two, the Pro Mags are a better value.
Old Feb 22, 2005 | 04:19 PM
Z95m6's Avatar
Ditto, i wouldn't waste my money on the magnums because you'll end up upgrading later. You could just get some nice used ones. I have a magazine laying around where they dynoed all the diff rockers and i think going from a roller tip to a full roller gained like 8 hp and decreased oil temp because of less friction.
Old Feb 22, 2005 | 06:11 PM
"White Knight"'s Avatar
No kidding, roller tips aren't worth it.....full roller is the only way to go--or else i'd just stay stamped steelies
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
