tach reads zero with engine running
Old Feb 19, 2005 | 07:00 PM
POLOVETTE 94's Avatar
I have a 94 LT1 Corvette, on which I have just installed the Delteq opti-direct 4 coil setup, among other mods. I started the car, and the tach never moved from "0", but the engine ran fine. Could this be related to the coil setup? I have checked the fuses and the grounds, where else should I look?
Old Feb 19, 2005 | 10:06 PM
kmook's Avatar
Advanced Tech Moderator
Re: tach reads zero with engine running
General engine troubleshooting should be posted in a engine tech forum.
Transferring, thanks.
Old Feb 19, 2005 | 10:28 PM
Beyonce Knowles's Avatar
Maybe somebody stole your engine and put in a hybrid. Check that first. Does it read zero all the time or only at idle? Could be a bad ground.
Old Feb 26, 2005 | 08:56 PM
I found the answer. My delteq opti direct system was one of the earlier ones, also with early directions. I happened to be reading the instructions on the website, and found the page about bypassing the tach filter only on 94-96 corvettes. I cut the 2 white wires and spliced them together, and the tach works fine now.
Old Feb 26, 2005 | 09:14 PM
neil350's Avatar
Good deal, how do you like the kit over all?
Old Feb 27, 2005 | 07:39 AM
So far, so good. The quality and fit of everything is top notch! But I haven't taken the car off the jackstands yet, so I can't really tell you about driveability
mr28
Apr 20, 2016 05:44 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
mr28
Nov 23, 2014 11:11 AM
Lions3
Apr 11, 2003 10:55 AM
z28projects4ever
9
Jul 16, 2002 07:48 PM
