M6... T-56 ? what do these mean?
Old Feb 20, 2005 | 08:09 PM
nonamez28's Avatar
ok well i have a 95 camaro z28 6 speed
and well i am new to domestics and just wondering what the hell these numbers mean, if someone could be my dictionary on these please?
thanks lol Chase
Old Feb 20, 2005 | 08:12 PM
96m6lt1's Avatar
Re: M6... T-56 ? what do these mean?
t-56 is the manual tranny in all f-bodies 93-97lt1 &98-02ls1 it is also called the m6 which is the order code..
RedRocketZ28's Avatar
Both are the same thing. M6 means that the transmission is a six-speed manual. T-56 is the name for the six-speed manual trans.
Old Feb 20, 2005 | 08:18 PM
Heatmaker's Avatar
Advanced Member
BorgWarner T-56
Old Feb 20, 2005 | 08:21 PM
nonamez28's Avatar
what? so t_56 9s 93-97 and m6 is for the 98 up ?
Old Feb 20, 2005 | 08:23 PM
Heatmaker's Avatar
Advanced Member
M6 = Manual 6 speed
A4 = Automatic 4 speed
the T-56 is just the Code for the tranmission.
The T-56 transmission is found in allot of cars from Auston Martins to dodge vipers.
T-56 is the model number of the tranmission.
Old Feb 20, 2005 | 08:24 PM
96m6lt1's Avatar
no m6 is on the rpo sheet, to determine if the car will have a manual trans(M6) or an automatic trans(A4) 4l60e.......
Old Feb 20, 2005 | 08:26 PM
nonamez28's Avatar
so basically t-56 and m6 are the same thing, but tehy are two different numbers for two different things?
Old Feb 20, 2005 | 08:28 PM
Pasky's Avatar
What is so hard to understand?
Old Feb 20, 2005 | 08:29 PM
Heatmaker's Avatar
Advanced Member
They are the exaxt same thing... M6 is just a code in the F-body world... but if you were to need parts for your transmission you would say "Do you have any gear Synchro's for a BorgWarner T-56 Transmission."
Old Feb 20, 2005 | 08:31 PM
nonamez28's Avatar
it isnt hard to understand, i am just making sure that i know.... and dont get things twisted, but i appreciate all the help
Old Feb 20, 2005 | 11:26 PM
M6 is a slang term for a 6 speed manual transmission. It could be any brand of transmission.
T56 is the model number of the Borg Warner 6 speed that is used in the f-body and some other manufacturers cars.
MM6 is the actual RPO (Regular Production Option) code you will find on the sticker located in the glove box or driver's door (depending on model year).
Or it can be M28 or M29 for two differently geared T56's that were used only in 1993.
All three transmissions are Borg Warner T56's.
G-BODYT56
Jan 14, 2022 11:14 PM
Henson071
Dec 30, 2015 09:55 PM
treyZ28
Mar 28, 2003 01:03 AM
GreenMonster138
Classic Engine Tech
Mar 26, 2003 02:14 PM
VentsWoker
West South Central
Nov 17, 2002 03:29 PM
