Can't Do a burn out. Need help!!!!!!!
Old Feb 23, 2005 | 09:51 PM
LUDA0840's Avatar
Arrow Can't Do a burn out. Need help!!!!!!!
I try to do a burnout and then the low traction light comes on the brakes get stuck and is hard to brake. Anyone know what might be wrong? I almost crashed today because of this.
Old Feb 23, 2005 | 09:53 PM
LUDA0840's Avatar
Re: Can't Do a burn out. Need help!!!!!!!
I have a 1996 Camaro Z28. Any idea what might be wrong?
Old Feb 23, 2005 | 10:03 PM
Knowklew's Avatar
turn traction control OFF
Old Feb 23, 2005 | 10:06 PM
LUDA0840's Avatar
the traction is on off. Its weird some light come on. Abs off and ASR off for no reason. What can be wrong?
Old Feb 23, 2005 | 10:29 PM
Kreinmc's Avatar
The low traction light will come on anytime the back tires spin. It will even come on if you go over a nice bump in the road. Here are a few reasons your car may not be able to burnout. 1. your brakes suck 2. your brakes are too good and the tires can't spin 3. your car is underpowered 4. your tires hook too hard 5. the pavement is too sticky 6. driver does not know what he is doing
Old Feb 23, 2005 | 10:31 PM
Knowklew's Avatar
i never get a traction light when i spin the tires
Old Feb 23, 2005 | 10:37 PM
black95z0122's Avatar
rev it to 5500 and pop the clutch
Old Feb 23, 2005 | 10:46 PM
LUDA0840's Avatar
the car is automatic
Old Feb 23, 2005 | 10:53 PM
Bow94z's Avatar
IM gonna go with # 6
j/k what about just stomping on it from an idle
Old Feb 23, 2005 | 11:00 PM
LUDA0840's Avatar
the low traction light turns on to, and the car loses power
Old Feb 23, 2005 | 11:42 PM
Cnadian_Camaro's Avatar
Sounds like your asr is on. I have an A4 as well all I have to do is boot it. If I boot it to hard I go nowhere just spin.
Old Feb 24, 2005 | 12:08 AM
TransAm2k4's Avatar
Yeah me too. When i had the A4 all i need to do was brake and accelerate. See some vid in my site. www.shpracingteam.comBut mine didn't have Traction control. Maybe your traction control switch is damaged.
Old Feb 24, 2005 | 12:17 AM
96lt1Camaro's Avatar
I vote #6
Old Feb 26, 2005 | 10:03 PM
LUDA0840's Avatar
I can do a burnout finally, the problem was that, there was too much air in the tires. Weird
Old Feb 26, 2005 | 10:34 PM
Eck's Avatar
Eck
Too much air in the tires can keep you from doing a burnout? Uhh... first off, I would think any LT1 could do a burnout, regardless of how much air is in the tires. Second, I thought more air would give less traction when compared to a tire with less air that puts more tire to the
