Uh oh! Stumble and stall!
Old Feb 22, 2005 | 06:38 PM
chevroletfreak's Avatar
Angry Uh oh! Stumble and stall!
I thought my car was sooo ready to hit the track again. I hav 130K miles on my 93Z. The last run I had was a 13.66 @107. Well, my H2O pump was weeping so I replaced it with a CSR. I also changed what ended up being a mismatched set of plugs and replace the stock wires with MSD 8.5's. The car has been GREAT for the last 350 miles of so and then all of a sudden it just died while driving at slow speed. It then happened 2 more times today so it wasn't a fluke. I watched and found that the idle is very irratic. It will speed up and then fall below stock idle without being coaxed. The oil pressure seems to be good as it fluctuates witth the idle speed. I also checked my wires and none seem to be shorted. Furthermore, there is no check engine light.....what can I look at before assuming.....OPTI?
Old Feb 22, 2005 | 06:40 PM
Dreamin69Dragy's Avatar
Re: Uh oh! Stumble and stall!
either a fouled plug or opti
considering your water pump went out sorta recent, im guessing opti, without a doubt
Old Feb 22, 2005 | 07:16 PM
What can I do to confirm anything? If it is opti related wouldnt I have recieved a ck engine?
Old Feb 23, 2005 | 06:05 AM
OK this is what I have found so far.
When I run the engine in the dark my coil does a little fireworks show as does my Opti to coil wire. I know my coil wire shouldnt do that, but is the coil suppose to flash with each spark?
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
tommalcolm
Sep 11, 2015 03:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
