Complete LT1 heater/radiator hose list?
Old Feb 20, 2005 | 09:05 AM
NVetro's Avatar
Complete LT1 heater/radiator hose list? Hose conversion?
Hey all, I searched for abit and saw those goodyear high milage hoses sells a complete kit for our car, minus 1 or 2 hoses I belive. But i was told they are blue! Not goin for that Does anyone have a COMPLETE list (including part numbers) of all the hoses needed for the 95-97 hose conversion on my 94 lt1(Heater and Radiator). Does this clean up the engine bay alot by not having that big bleeder T that the 94 has? I am swaping in a 383 stroker and want everything to be perfect.I looked at Shoebox's site, found a few of them, but not all....thanks in advance! Anything else you guys think i should be replacing for this new motor swap?
Old Feb 20, 2005 | 04:37 PM
NVetro's Avatar
Re: Complete LT1 heater/radiator hose list?
anyone?
Old Nov 21, 2005 | 10:32 AM
NVetro's Avatar
i know i posted this awhile ago, but I still need this information if anyone can help me out......the PDF that has all our part numbers seems to be alittle off, its missing a few hoses and the diagram doesn't even show 2 ports on the water pump, so i dont want to go by that......Any help would be appricated...
EDIT: I need the 95+ hose part numbers, since ill be converting..
Old Nov 21, 2005 | 04:25 PM
Flmac02Z's Avatar
There is a kit you can get from Goodyear and it's the high miler coolant hose set....I ordered mine, only had to trim a couple inches off some and they were all there and they all fit. Only problem I had was that i had to remove competely the bleeder valve at the top of the water pump, the one that is still at the waterpump housing is the main one I use now. Give me a couple of minutes and i'll edit this post with the link to buy the kit.
~Kevin
EDIT:
The part number on summitracing is GTR-5006. That is for 95-97 Camaro/Firebird LT1
http://store.summitracing.com/defaul...=egnsearch.asp
Also if you go here and put in your car info(year, make, ect.) then you can get the individual part numbers.
http://www.goodyearbeltsandhose.com/...zX6cr:uur6cg6k
Old Nov 21, 2005 | 04:53 PM
NVetro's Avatar
ive heard bad things with the goodyear kits, plus i dont want blue hoses.....thanks though..
Old Nov 22, 2005 | 03:24 PM
Flmac02Z's Avatar
This is the only other thing I can think of to help you out. I haven't seen any webpages or sites on converting the coolant systems. Compliments of Shoebox.
http://shbox.com/1/Parts.htm
Hope that helps.
~Kevin
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
