Quick Timing Question.
I will be installing my timing chain tomorrow and I was curious since I have the GM847 which has 4 degrees advance ground into it where I need to set the cloyes timing chain. I have the option for 4 degrees retard, 4 degrees advance and 0. I was pretty sure to just set it to 0, but I wanted to make sure.
Thanks.
Kendall H.
Thanks.
Kendall H.
Re: Quick Timing Question.
Since you had 4* built into the cam, I would degree the cam just to make sure it is ground accurately. If it is, then install it at "zero". If not, you should advance/retard it accordingly.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jan 23, 2015 01:13 PM
