Problems at start up
Old Feb 21, 2005 | 04:42 PM
TransAmGT94's Avatar
The car runs fine after i start it up and get it running. It acts like a carbed car with choke issues on start up after it has been sitting for 30 min or so.
I just replaced the fuel pump because the stock one went out. I have a new Iac, Tps, Map, Starter Opti, Plugs and wires. When it does start it idels around 1500 till it settles down to the normal range
Any ideas on what to change next would be great.
Chris
Old Feb 21, 2005 | 04:45 PM
JDBlaze85's Avatar
Re: Problems at start up
Cts?
Old Feb 21, 2005 | 04:52 PM
Car temp reads fine
Old Feb 21, 2005 | 06:53 PM
ftransam1's Avatar
I'm having the same problem now too. Let me know what you find
Old Feb 21, 2005 | 06:55 PM
slimdawson's Avatar
I am not sure I see the problem. Is it the fact that it idles a little high at first? If so, for how long? It is normal for it to idle high at first.
Old Feb 21, 2005 | 07:04 PM
Dave89IROC's Avatar
I'm with slim, exactly what do you see as a problem? the high idle that drops to normal as it warms up?
Old Feb 23, 2005 | 12:32 AM
mebanditws6's Avatar
I was with Chris when him and another guy helping him got the fuel pump on. When the car starts, it sounds like it's cammed for a little bit until it starts idling at 1500ish, smooths out, then settles down again to around 900. Once it settles down like this, it runs normal. It doesn't blow out any black smoke from running rich, just runs rough like it has a pretty warm cam in it. It did this with the fuel pressure at 35lbs where it's at now and even when it was at 70lbs before he turned it back down with the regulator. Also, it's kind of hard starting when cold unless you turn the key on and wait a few seconds for fuel pressure to build, then it's fine. Just thought I'd clarify things.
Jason
Old Feb 23, 2005 | 04:43 PM
the problem is that it dies when it starts because idle is low it feels like a carbed car with choke issues when you give it the gas to raise idle it doesnt want to rev until it warms up for a while then drives fine
Old Feb 23, 2005 | 09:52 PM
slimdawson's Avatar
Does it have egr?
Old Feb 24, 2005 | 08:14 AM
no
Jason
Old Feb 24, 2005 | 05:06 PM
slimdawson's Avatar
Check your Maf connections. Also, try cranking it with no maf. Unplug before you start it up.
Old Jun 2, 2005 | 10:29 PM
st_paul's Avatar
I am also having the same problems. Mine dies after start-up unless you give it gas for 10 seconds or so then runs great.
Old Jun 4, 2005 | 07:57 PM
Blacksmith's Avatar
somebody help me too. i've replaced the egr valve, ecm, spark plugs, wires (a year ago), battery, starter, fuel filter, trans has been rebuilt with slight mods, added cold air intake, ignition fuses and ignition coil. the car is getting fuel because i can get it started on rare occassions. i don't know if i need an ignition module, tps, or distributor. i need some help here guys.
Old Jun 4, 2005 | 09:09 PM
JDBlaze85's Avatar
scan the sensors with a scan tool and see what your sensors are doing. I would suspect your coolant temp sensor first.
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
