Tricking the comp about ASR??????
Old Feb 21, 2005 | 01:22 PM
eagleknight97's Avatar
Question Tricking the comp about ASR??????
Ive been trying to figure out ways to remove my ASR while still retaining my ABS. I have asked before and to no avail for the most part. I have an OBD-II car, with ASR, and really want to remove it. The standard response is, just unplug it and get a new throttle and cruise cable. That doest work with OBD-II cars at all. It is my understanding that OBD-II cars use a different style ABS pump so simply removing it will cause the ABS to be inoperative. I know there was an attempt a while ago at buying a new ABS pump and some other stuff to try to work it out, but havent heard anything with that. But i was thinking the other day, and what if I somehow used a resistor in the wiring for the ASR to simulate the ASR module still being there? Could that trick the computer into thinking it was still there???
Old Feb 22, 2005 | 01:30 PM
Re: Tricking the comp about ASR??????
Anybody? Nobody? Bueller?
Old Feb 23, 2005 | 02:14 AM
Cnadian_Camaro's Avatar
Pull the B relay under the hood no more ASR. Also you keep the ABS.
Old Feb 23, 2005 | 03:03 AM
nin97's Avatar
usually i just turn off ASR right after i turn the car on...its a habit now...but when i'm forcing myself not to rape my car i turn it on...and it reminds me not to pull stunts
Old Feb 23, 2005 | 10:42 AM
Yeah, I turn it off most of the time also, but my main reason for getting rid of it is because it looks so ugly under the hood. And Cnadian camaro, have you yourself pulled the b relay and done this and then actually removed the actual ASR box off the engine and still retained ABS?
Old Feb 23, 2005 | 11:12 AM
No sorry didnt relize you wanted it out of the car but ya ive pulled the relay and its off now. I used to always forget to shut it off this way its always off.
13qtr
Oct 28, 2016 08:11 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
