What would make THIS noise!!
Old Feb 23, 2005 | 03:39 PM
RUFST's Avatar
While my car is idleing i can hear what appears to sound like a supercharger belt whining.....i mean if ppl didn't know you would think one was on my car.....is it a bad belt....the reason i don't think it is...is b/c when i accerlate it don't sqeal like a belt slipping or going bad
what do you guys think it is
i can take a video of my car idling and mail it to ya if you think that would help solve my problem.....theres no hp lose or anything no codes nothing but a as i stated above a supercharger type sound not a SQUEAL coming from the engine bay
Old Feb 23, 2005 | 03:55 PM
tamatt27's Avatar
Re: What would make THIS noise!!
It may be your alternator or one of your pulleys.
Old Feb 23, 2005 | 04:16 PM
slimdawson's Avatar
Do you have a supercharger? That could be it
Take your belt off to narrow it down to an accessory. Check the belt tensioner and anything else that spins. Is your ps reservoir full?
Old Feb 23, 2005 | 05:53 PM
RUFST's Avatar
shew i wished i had a charger
i'm not sure what you mean by take the belt off to narrow it down...you mean replace it.....to see if it fixes it??
Old Feb 23, 2005 | 06:09 PM
Dave89IROC's Avatar
no, take the belt off, then start the engine, if the noise is gone, turn the engine off, then turn the pulleys by hand(crank pulley on the bottom wont turn) , they should all turn smooth(might have slight resistance from the P/S pulley, but it will turn ok
Old Feb 23, 2005 | 06:13 PM
RUFST's Avatar
oh i'm sorry......i wasn't sure you could start the engine with the belt off the car......i'm not questioning your expertise but are you sure that won't hurt my engine running w/o a belt?
Old Feb 23, 2005 | 06:20 PM
Dave89IROC's Avatar
water pump is cam driven, plus you won't need to run it for more then 30 seconds to 1 minute
Old Feb 23, 2005 | 06:35 PM
blind527's Avatar
damn i am having that same problem, i can only tell at idle too. it's pissing me off, it's high pitched as hell!
Old Feb 23, 2005 | 06:40 PM
1racerdude's Avatar
Sometimes alternators have a high pitched cycle noise that is due to its charging the bat. It can't be elimanated without changing the alternator and you still may have the noise with a new one.
Old Feb 23, 2005 | 07:17 PM
ulakovic22's Avatar
I would guess power steering pump also, but that's all it is, a guess.
Old Feb 23, 2005 | 07:41 PM
LT4orbust's Avatar
try listening under the car behind the front tire , possibly something in the clutch or the cover on the front of the trans
Old Feb 23, 2005 | 08:32 PM
chevroletfreak's Avatar
I have been trying to fix the same thing.
So far I have replace the alternator, PS pump and the belt. I am pretty positive it is my AC compressor. because it has been low for quite awhile and because there is not much left. Good luck
Old Feb 23, 2005 | 09:45 PM
slimdawson's Avatar
You can safely crank the car without the belt on. Be careful of moving parts though when it is on. I have bad visions of what could happen if a piece of you gets caught in a belt but at least it has kept me safe.
If you can get a stethoscope or even a long screwdriver, you can pinpoint where it is coming from. Just put your ear up to the screwdriver handle and the point on whatever object you are listening to.
Old Feb 24, 2005 | 09:32 AM
LT4orbust's Avatar
absolutely be careful around moving parts, i saw a sun dianostic machine arm and all to leads pulled into a engine compartment , almost tipped the machine over, loose clothing can cause the same thing , turn the air coditioner on and off to see if the noise changes
Old Feb 27, 2005 | 02:53 AM
RUFST's Avatar
hey thanks i didn't know that you learn something new everyday huh ...i'll give it try doesn't seem to be a big problem b/c its not throwing a code or reducing driveablity
warmeck
Mar 22, 2015 10:28 AM
Fatdog2
Feb 12, 2015 12:24 PM
warmeck
Feb 5, 2015 11:04 AM
jcamaro95lt1
Jan 24, 2015 08:21 AM
squarehead
Nov 21, 2014 08:02 PM
