rebuildage
Old Feb 23, 2005 | 12:12 AM
laxwarriors21's Avatar
rebuildage
Hey all, I am commin' from a '96 jeep grand cherokee to and '94 Z28 and was wondering how much a engine rebuild would be, the z28 has 145k miles thats about all I know! thanks for any help
Old Feb 23, 2005 | 12:18 AM
neil350's Avatar
Re: rebuildage
Depends on what you want done, stock rebuild or stroker? Lots of options open for what you want to do with.
Old Feb 23, 2005 | 12:21 AM
Re: rebuildage
haha dunno... jsut stock rebuild i guess
Old Feb 23, 2005 | 01:31 AM
Silvershark's Avatar
Re: rebuildage
A stock rebuild runs around $1000 - $1200 around here for a shortblock.
$120 to turn crank .010
$300 for freeze plug install, bore, align, hone, magnaflux and check block.
$300 for assembly.
$300 for balancing the assembly.
Plus what ever it costs to recondition your stock pistons and rods and new ring sizes etc.
I purchased all my parts and just paid labor charges and the block work. So thats about all I can help you as far as prices go.
Old Feb 23, 2005 | 10:54 AM
JohnD's Avatar
Re: rebuildage
Got oil pressure at idle? Run a compression check too-you may not need a rebuild for a long time.
Old Feb 23, 2005 | 11:58 AM
Re: rebuildage
just thinkin of buyin a z28 with 145k miles on it
Old Feb 23, 2005 | 12:09 PM
Re: rebuildage
I bought mine with 150k and it ran real strong right before i tore it down. The only reason i decided to rebuild it was that I had pretty high goals for the car down the road and the oil pan was leaking and I just decided to pull the motor and get it done with.
Old Feb 23, 2005 | 09:08 PM
Re: rebuildage
I see... I am debating on this Trans Am or this Camaro, what would you guys reccomend?!
Old Feb 23, 2005 | 10:27 PM
Bow94z's Avatar
Re: rebuildage
Even though i drive a Z28. i would go with the T/A. Its got lower miles, Full exhaust already done, PLUS ITS A 6spd< cant turn down that.
Old Feb 24, 2005 | 01:02 PM
1SlowFormula's Avatar
Re: rebuildage
I agree! BTW, it is a formula not a TA
