Fuel rail clips
Old Feb 19, 2005 | 04:58 PM
whatsup's Avatar
Fuel rail clips
Starting to assemble a spare intake and rails to swap out and noticed the extra rails I bought does not have the little PITA clips the help hold the injectors in place. The guy I bought the rails off of says this is the way he was running them??? So are they needed or not? If so where can I get them?
Old Feb 19, 2005 | 08:01 PM
Hawk's Avatar
Re: Fuel rail clips
they hold the harness down. I don't know where you can buy them seperately, but i know for a fact that if you buy just the harness (advance auto has them) each connector comes with the clip.
Brian
Old Feb 19, 2005 | 08:38 PM
RE AND CHERYL's Avatar
Re: Fuel rail clips
In the factory the injectors are installed in the rail long before the rail and injectors are installed on the intake. The clips are unsed to keep the injectors from falling out. You don't need them at all.
Old Feb 20, 2005 | 10:16 PM
Lt1t56's Avatar
Re: Fuel rail clips
I have ran my car without them and had no problems, they are nice to have if you plan on removing the fuel rail again so the injectors will come up with the fuel rail.
Old Feb 20, 2005 | 10:19 PM
turbo_Z's Avatar
Re: Fuel rail clips
If you had larger injectors, youd notice the clips wont even fit. I havent had any problems with the injectors falling out running w/o them.
HectorM52
Jul 30, 2017 11:46 AM
ad356
Apr 16, 2015 05:38 PM
dfarr67
Apr 10, 2015 07:44 PM
4586
Feb 13, 2015 09:16 AM
dreamer1q
Aug 29, 2002 07:47 PM
