Richmond whine. 2.73's to 3.73's problem
Old Feb 18, 2005 | 09:28 PM
Droff's Avatar
Has anyone put Richmond gears in and not whined? I have read it's hard to get Richmond to not whine because on the cut. I have 2.73’s and I am putting in 3.73’s. So I have a 2 series carrier. My mechanic says the only ones that make 3.73’s on a 2 series is Richmond and GM. The Richmond is ~ $200 the GM are ~ $900. We are having big trouble getting the gears to not whine on deceleration.
My big question is how much would a matched set Moser set be? Do I NEED a different carrier or a ring gear spacer to put the Moser on? I would think the Moser’s with a new carrier would be more that 200 but less than 900 and not whine. I have read on here that people have used Moser and NOT whined.
I am trying to decide if I should send the Richmond back and get everything I need for the Moser’s.
For those who have gone from a 2.73 to 3.73 what have you done to make it work, and does it whine?
THANKS!
Old Feb 18, 2005 | 09:38 PM
blind527's Avatar
Re: Richmond whine. 2.73's to 3.73's problem
i'm curious too....does it matter what carrier?? i'm gonna go from stock to 3:73 as well.
Old Feb 19, 2005 | 12:18 AM
Mr Kevlar's Avatar
Strange also makes a 3.73 for a 2 series carrier. $225
They wine a little on acceleration, only because I didn't get the pinion depth perfect when I installed them.
www.thunderracing.com
Old Feb 19, 2005 | 12:39 AM
brokeTA's Avatar
Its all in the pinion depth. Me and Sweetred95ta installed his 3.73s and they are just about perfect.
Old Feb 19, 2005 | 02:41 AM
Don't Look Back's Avatar
I went from 2.73's to Richmond 3.73's and mine do whine. They were really bad at first, so I reshimmed them and that helped a lot. They still whine up until about 3,000 RPMs. I read all the same things you probably did saying how hard it is to not get them to whine. I was also told the same thing by one of the best car building/rear end places in Jersey. Just put on a set of long tube headers and you won't hear it anymore, I don't.
Old Feb 19, 2005 | 10:34 AM
blind527's Avatar
what is a 2 series carrier and what do i need for my 97 formula?
Old Feb 19, 2005 | 10:56 AM
heliskiier1's Avatar
I got Richmond 3.73's ....went from the 3.42's....no whine at all, but unless you really know what you're doing, get an expert to put em in. it's worth the $$$. I wouldn't attept it myself and I'm not bad with the wrench.
mudkat
Old Feb 19, 2005 | 11:00 AM
blind527's Avatar
how much is it for an expert??
i also thought about getting a new FULL rear end with everything around 2400
Old Feb 19, 2005 | 11:44 AM
$299 for gears, install kit and pinion bearing...estimating $250 for the install. i had it done at same time i had plugs, stat, hooker shorties, plug wires and hi-flo cat done and total labor for all was $950. shouldn't be more than $600 for the parts and install...F-Body Motosports in Charlotte did mine. Find a shop that specializes in the F-Bodies and u should be fine.
kat
Old Feb 19, 2005 | 11:46 AM
blind527's Avatar
i did the stat, cat back, plugs myself.
so the gears will cost about 299 + about 300 for installation? where can you get it done if i can't find a shop that specializes in f bodies?
maybe i'll get them put in when i get LT headers and a y pipe.
oldschool
Feb 9, 2016 09:21 PM
Z28amustangklr
Middle Atlantic
Mar 28, 2015 03:08 PM
blac94Z
29
Mar 25, 2015 04:21 PM
737drivr
Feb 20, 2015 11:54 AM
Jessie4tin
Jan 7, 2015 08:53 AM
