Broken timing chain
Old Feb 22, 2005 | 05:57 PM
hondah8ter's Avatar
Broken timing chain
like the title says i broke my timing chain under full throttle, but i was wondering what the chances are i bent some valves? or anything else that might have happend. thanks
Old Feb 22, 2005 | 05:59 PM
Re: Broken timing chain
Chances are good that you smacked a few valves.
Old Feb 22, 2005 | 06:00 PM
Janny's Avatar
You would be very lucky if you don't have bent valves, and a few holed pistons is also a very real possibilty. Heck I had a timing chain let go once while starting the engine and had a mess of bent valves.
Old Feb 23, 2005 | 01:57 AM
hondah8ter's Avatar
thanks for your reply's
Old Feb 23, 2005 | 02:03 AM
Rob(94Hawk#319)'s Avatar
Just out of curiousity, what kind of timing chain?
Old Feb 23, 2005 | 02:05 AM
SStrokerAce's Avatar
Did ya change the cam too?
Most times a broken timing chain is due to the cam gear and crank gear not being lined up. I always think it's a good idea for most guys to leave the timing chain be or just change the chain when they do a cam swap. Usually the problem is the crank gear not being pressed on the crank enough.
Bret
Old Feb 23, 2005 | 08:07 AM
1-bad-z28's Avatar
man, that sucks
Old Feb 23, 2005 | 04:49 PM
hondah8ter's Avatar
stock cam and stock timing chain. the chain broke in one place and was about to break in another.
Old Feb 23, 2005 | 06:07 PM
Robs97Z28's Avatar
how many miles were on the timing chain?
Old Feb 23, 2005 | 07:19 PM
Loading's Avatar
I thought our engines were none interferance.
I thought that meant that if the timing chain snapped, the engine would be 'safe?'
Old Feb 23, 2005 | 08:16 PM
Spinner's Avatar
These aren't mazda miatas.
Old Feb 23, 2005 | 09:12 PM
That is an apparent matter for debate.
Old Feb 23, 2005 | 10:59 PM
Flip94ta's Avatar
With my cc305 and 1.6's and dished pistons I have .544 lift and my intake valves all hit the pistons when the timing chain was installed wrong by the builder. The stock pushrods will bend, and if they dont bend the intake valves will bend. The stock lift is only .460. So I would check the intake pushrods and replace if necessary. Next, do a compression check, mine was zero so thats pretty clear. I'd say your chances are 50/50 on the valves being bent.
Old Feb 24, 2005 | 12:38 AM
Z95m6's Avatar
its funny that this guy broke a stock chain on a stock motor, and yet most of the idiots on this site say stock chains are ok to run with heads and cam motors.
To the original poster i would say your probabilitly is high you bent some valves.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
