Transmission Bolt Extraction
Old Feb 21, 2005 | 01:27 PM
93ZM6Tally's Avatar
I'm rebuilding a T-56 and whomever had it open last ruined the two case bolts that hold the shift guide plate to the case. These are a couple of Torx head bolts, one is broken, the other hoplessly stripped and apparently really torqued in there. I'm at the point of attempting to drill them out but so far haven't found a drill bit that even seems to make a dent. Hardest drill bit I can find in town is the Cobalt type and these have hardly made a dent. Aren't there harder drill bits out there, carbide? Where could I get them. Next step if I can't get them out myself is to try and find a machine shop in town that will take them off for me, but I'd like to do this myself. Oh and btw I don't have a welder, and if I did, I don't know how to weld.
Thanks.
Old Feb 21, 2005 | 01:40 PM
stik6shift93's Avatar
Re: Transmission Bolt Extraction
I'm not really familiar with what bolts your are talking about however they sell extraction kits. These are basically a drill bit and a screw with the threads reversed on it. You basically drill the bolt and then just screw in the screw until it bottoms out and then put a wrench on it.
Victor Lamb
Aug 26, 2017 02:52 PM
PublicEnemy1
Apr 7, 2015 12:21 PM
maybe2fast
Mar 16, 2015 09:45 AM
95chwagon
Feb 28, 2015 12:02 PM
thenewkid
Nov 27, 2014 09:41 AM
