putting in new converter rear main seal question?
Old Feb 20, 2005 | 08:26 PM
red96z's Avatar
doing the converter swap this week at this time should i change the rear seal.its not leaking but just wondering since i will be in the neighborhood?it is pretty easy since the trans will be down right?anything else i should look into while doing the swap,or maybe u guys have done during a converter swap.
Old Feb 20, 2005 | 08:41 PM
mohawkmike's Avatar
Re: putting in new converter rear main seal question?
Yeah its easy & quick enough that if I were you, Id change it. Be careful not to damage the pan gasket if you take the seal housing off the block.
Old Feb 20, 2005 | 11:32 PM
mohawkmike is not inferring you have to, but there is no need to disturb the rear main housing when replacing the rear main seal. Only if you have a leak at the seal housing to the block would you have to mess with it. I would check the seal housing bolts/nut to be sure they are tight. Sometimes they like to work loose.
Old Feb 21, 2005 | 09:52 PM
red96z's Avatar
its not leaking just thought i would change it since i will be in the neighborhood or should i leave it alone?
Old Feb 21, 2005 | 10:31 PM
At 85k, mine was showing signs of slight leakage-just a little oil on the back of the pan. Consider what you have to do to get to it if it leaks and make a judgement call from there.
PCLZ28
Dec 24, 2015 05:19 PM
Patricklt1
Apr 24, 2015 06:29 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
