biggest ci?
Old Feb 21, 2005 | 09:38 PM
DiabloGT's Avatar
biggest ci?
whats the most biggest ci stroker they sell for the lt1 camaro, is there any bigger than 396, and is there any link to buy it? and/or how much does it cost
thanks
Old Feb 21, 2005 | 09:50 PM
1racerdude's Avatar
Re: biggest ci?
thanks
A 396 is about as big as you want to go in a factory block,because of clearance issues.
You can build a 454CID small block with an aftermarket block with no issues----- Bring your checkbook----- lots of special stuff to buy like heads big enough to feed it and a sheetmetal intake. That is if you want it to make the HP it is capable of.
Cubic bucks is all it takes.
Old Feb 21, 2005 | 09:54 PM
DiabloGT's Avatar
Re: biggest ci?
oh ok, do you have any links that sells the 396?
thanks but how come some of the ls1's i heard can get 455ci???
Old Feb 21, 2005 | 10:02 PM
1racerdude's Avatar
Re: biggest ci?
Ya ain't building a LS-1.The blocks are two completely different animals. I don't think you can go that big in a LS-1 factory block that comes in Camaro's.
Old Feb 21, 2005 | 10:23 PM
DiabloGT's Avatar
Re: biggest ci?
Does anyone have any links to buy the 396 stroker?
Old Feb 21, 2005 | 10:29 PM
1racerdude's Avatar
Re: biggest ci?
Do a search for Probe Industries,Scat,Eagle,Cola,and several others.
LT1 Bunny's Avatar
Re: biggest ci?
if you want to get serious, i would check out more performance...they have a few packages for ltx motors, lsx motors. If you really have the cash flow then I would highly recommend their 427 c5r motors. I think the 427s are around 25 gs or so. But you can also get to 700+ levels with that motor.
Old Feb 21, 2005 | 11:29 PM
Heatmaker's Avatar
Advanced Member
Re: biggest ci?
Your looking at boku bucks dude.... hope you have atleast 10-16K on standby.
Old Feb 22, 2005 | 12:30 AM
Pasky's Avatar
Re: biggest ci?
Cnc-motorsports.com
They had a forged rotating assembly for $1500 I believe. I am so tempted to get this.
My question is this without throwing it off topic.
How many miles can you expect to see out of a 396 with a couple track meets a month and daily driving?
http://www.cnc-motorsports.com/produ...095&CtgID=9038
Old Feb 22, 2005 | 03:55 AM
onebadponcho's Avatar
Re: biggest ci?
We are still talking about LT1s, correct?
If so, the biggest ones I've heard of are 409 CID. TPIS built it and called it the ZZ409. 4.04" bore by 4" stroke I believe.
A guy can built a 383 for almost the same cost as a 350; but you start getting bigger than that, the cost goes up exponentially. IMHO, it's better to build the 383 and put the money you would spend going for another 13-26 CID on better heads.
Old Feb 22, 2005 | 04:04 AM
96m6lt1's Avatar
Re: biggest ci?
badd head-doesnt get you there
good head-always gets you started
best head-gets you finished quicker
Old Feb 22, 2005 | 11:01 AM
Dave88LX's Avatar
Re: biggest ci?
Check out www.adperformance.com
I'd take the money that you were going to put into some special 409 or whatever, keep it a 396 or 383, and put the extra money into heads and valvetrain.
Old Feb 22, 2005 | 11:13 AM
DavesLT1's Avatar
Re: biggest ci?
I just bought a 396 kit internally balanced for 1800, figure another 7 grand for heads/cam and rebuild. you need to look at around the 10 thousand area for the whole thing with parts and machine work, plus a few bumps. I wouldn't recommend anything bigger as the cylinder walls on these blocks get very thin beyond a .030 overbore. if you really have money to burn, buy a built up big block and go from there. but for that money a 383 or 396 with a turbo/supercharger would probably satisfy your wants for anything on the street.
WPHIG2
Aug 27, 2015 06:37 AM
whitehooptie
Jul 12, 2015 06:10 PM
jackpawt883
May 21, 2015 12:34 AM
blkWidow
Apr 20, 2015 09:27 AM
pecaspickles27
Wheels and Tires
Jan 20, 2015 02:31 PM
