Cloyes double roller instruction manual
Old Feb 21, 2005 | 06:58 PM
Pasky's Avatar
I forgot which circle and which keyway to line up for stock timing advance. Anyone have the instruction sheet because I can't find mine? Thanks.
Old Feb 21, 2005 | 07:47 PM
LT1 Bunny's Avatar
Re: Cloyes double roller instruction manual
on the crank gear there should only be one keyway....as for the rest, line them up dot to dot.
when you stick the crank gear on, rotate the crank until the dot is at the 12 o'clock position (the big dot on the very outside, not the plus or minus or other dot) then stick on the cam gear with the bolts in it. move it until that dot is at the 6 o'clock position. make sure it is absolutley correct! being off by on tooth advanced or retarded could pretty much screw up everything. when you dot to dot, take the cam gear off, put on the new chain with the cam gear and play with it untill it goes on correctly.
when the chain is on...recheck it by moving the crank and make sure those dots line up!!...if they dont then just redo it over again! doesnt take that long to recheck everything. example, if i didnt recheck it...i would have been off by one tooth.
Old Feb 21, 2005 | 07:57 PM
Pasky's Avatar
No no no, I know very well how to install it, thing is, mine has 3 crank keys and 3 dots.
Old Feb 21, 2005 | 07:58 PM
Pasky's Avatar
My double roller is jegs part #:
220-9-3145
I left my instructions at my buddies shop and he is in Acedemy school now.
Old Feb 21, 2005 | 08:05 PM
LT1 Bunny's Avatar
oooooooooooh, alrighty then.
what are right above the key ways? other than teeth
Old Feb 21, 2005 | 08:08 PM
One of the marks should be round. That is straight up, without advance or retard.
Old Feb 21, 2005 | 08:13 PM
Pasky's Avatar
Dot or crank key shoebox? Im pretty sure the correct crank key is the square with a rounded edge.
Old Feb 21, 2005 | 08:18 PM
LT1 Bunny's Avatar
i was thinking that one of the keys should be a dot as well. but i forget now, its either dot or square with a rounded edge????
Old Feb 21, 2005 | 08:19 PM
Pasky's Avatar
Yea, the crank key is like a square, a square with a rounded edge and something else. The dots are like a triangle, a Circle and another circle, one is oval I think, let me go outside and double check.
Old Feb 21, 2005 | 08:21 PM
I thought the crank gear had a square, triangle and circle. The circle (or dot) should be straight up.
Old Feb 21, 2005 | 08:24 PM
Pasky's Avatar
THe dots are, triangle, square and circle.
Old Feb 21, 2005 | 08:25 PM
Pasky's Avatar
Cam gear has a dot (big gear). The hub gear has 3 keyways, and im sure I used the right one. It also has 3 timing marks, square, circle and triangle. Don't remember which timing mark to use. Just phoned my buddy and he doesnt remember when we put the cam in.
Old Feb 21, 2005 | 08:31 PM
LT4orbust's Avatar
the half moon looking keyway is factory , or 0 advance
Old Feb 21, 2005 | 08:34 PM
LT4orbust's Avatar
the half moon looking keyway is factory , or 0 advance, the o on the gear tooth
Old Feb 21, 2005 | 08:36 PM
That's what I have been saying.
