Taller valve covers with guidepates????
Old Feb 19, 2005 | 02:48 PM
ChevyTuffD.A.'s Avatar
Hey guys, I am about to buy a set of comp cams pro mag NSA 1.6 roller rockers. Now i know I need guideplates bc they are NSA but my friend said that i would need to buy taller valve covers bc the guideplate will raise the stud bolts up a tiny bit, is this true?? I am going to be running a hotcam on a 110lsa if that matters. Thanks alot, Dustin.
Old Feb 19, 2005 | 02:56 PM
Re: Taller valve covers with guidepates????
The guideplates and subsequent slight raising of the studs will not require a valve cover change. You will only have to worry about clearancing the covers for the ProMags.
Fastbird93's Avatar
I'm running Comp 1.6 NSA rockers, GMPP guideplate, and ARP studs under the factory covers. YOu'll be fine.
Old Feb 19, 2005 | 03:01 PM
OBE1 95Z28's Avatar
The webbing inside the stock valve covers that support the "bolt tubes" will need to be trimmed. Only the upper sections need to be removed.
Old Feb 19, 2005 | 03:45 PM
Alright thanks alot guys. I have always heard that the valve cover braces or whatever they are called needed to be trimmed, does anyone know where i can find a picture of what exactly to cut??
Old Feb 20, 2005 | 01:18 AM
trans9_5am's Avatar
You do not need to cut anything off of them! All you need to do is take a pair of pliars and bend the supports so that they are totally flat. And on the oil breather, bend the side walls so that it is flat as well. I have a complete write-up saved on my other computer but i will not be able to access it unitl sunday evening. If no one gives you the link before then, ill send it to you. Its very detailed and easy to follow and this way you dont have to worry about losing the strength of the stock valve covers over time.
Brandon
Old Feb 20, 2005 | 01:52 AM
Yea man that would be cool if u kewl do that, i would appreciate it.
Old Feb 20, 2005 | 02:08 AM
snakethis69's Avatar
Brandon
i would like that link also i am about to do cam/1.6 NSA RR's also
Old Feb 20, 2005 | 10:40 AM
stereomandan's Avatar
http://web.camaross.com/forums/showt...ht=valve+cover
I made that post specifically to answer the question you have.
Dan
Old Feb 20, 2005 | 10:47 AM
trans9_5am's Avatar
Yes follow that link. That is the exact article if went by. Easy as ever. Thanks man.
Brandon
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jan 30, 2015 11:34 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
thenewkid
Nov 29, 2014 04:54 PM
