insanely dumb question....
Old Feb 19, 2005 | 10:38 AM
Quick96Z's Avatar
I am installing a roller pilot bearing when i do my clutch swap and i was wondering how much and what kind of grease i should use? I know this is retarded, but do i use hi temp wheel bearing grease, or regular stuff or nothing at all?
thanks
trav
Old Feb 19, 2005 | 02:28 PM
Z95m6's Avatar
Re: insanely dumb question....
I used wheel bearing grease. I might suggest staying away from teh roller bearing ones and use a bushing. I've heard bad stories about rollers going bad and they tear up the input shaft on the tranny.
Old Feb 19, 2005 | 02:57 PM
OBE1 95Z28's Avatar
Another vote for using a bushing.
Old Feb 19, 2005 | 10:13 PM
Quick96Z's Avatar
really!?! i was always told that the bearings are better..that is weird.
what exactly happens with the bearings? Thank you guys very much for the new info and saving me a potentially huge mistake...
trav
Old Feb 20, 2005 | 10:38 AM
OBE1 95Z28's Avatar
The bearing is more fragile, and if it comes apart, you'll have metal peices bouncing around damaging things. Nothing to break with a bushing.
Old Feb 20, 2005 | 11:20 AM
Robs97Z28's Avatar
I have had a bearing fail. i was lucky that the input shaft wasn't harmed. The main reason bearings fail is lack of grease. Since I the bearing and the clutch, I haven't has any trouble with either. I now have 80,000 mile on both. The key is to pack the grease into the needle bearings.
Old Feb 20, 2005 | 11:55 AM
Quick96Z's Avatar
i see, do you think it would just be easier to skip the bs and stick with the bushing...i mean atleast this way there is no risk of it flying into pieces.
trav
truecontr3
Oct 11, 2015 09:30 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
pimpen1024
Aug 19, 2015 08:36 PM
Aug 7, 2015 01:26 PM
surreybrad
Jul 29, 2015 02:55 PM
