What Tools for Header install...
Old Feb 23, 2005 | 11:52 PM
97BBlackZ's Avatar
Hey, Just wondering if anyone can give me any info or a list of what tools i will need for my header install..
I'm just asking because im going to attempt it Friday and don't want to be out a tool that i really need and have to run and go get it. Do i need any extensions if so how long, Short of deep sockets? tq wrench? ect. 02 Socket? Just wondering because im basically working with what ever tools my dad has and i'm not sure its all there.
Thanks for any help,
Old Feb 24, 2005 | 12:01 AM
Spinner's Avatar
Re: What Tools for Header install...
12 pack of your favorite beer. O2 socket WILL NOT BE ABLE TO REMOVE THE O2s because they will be so rusted tight. Get a 7/8 line wrench (flare nut wrench) to remove them if your going to try to reuse them. Lots of wrenches, closed and open. Lots of extensions of all lengths.
Be sure to drain oil, filter, disconnect battery and drop starter before starting.
Old Feb 24, 2005 | 12:24 AM
97BBlackZ's Avatar
I'll go through what's here tomorrow and see what he has. I know I have most of that just scatters through a lot of those Tool kits you buy haha.
So do you think i just just buy some new 02? I'm also doing plugs and wires along with it. I still need a spark plug socket to right?
Also what about the AIR and ERG system. Is there a way that i can block it off till i can get some block off plates? Do you have any tips?!
I pretty much plan on taking pictures of everything just to make sure it goes back on the right way and make sure everything is in place.
And what about moving the motor around if needed? It is ok to just place something between the oil pan and the jack to list the motor up? How hard are the bolt going to be to undo?
I plan on getting some PB Blaster? I think is what someone said to spray on the bolts over night so they will be easier to get loss..
Old Feb 24, 2005 | 12:46 AM
Don't Look Back's Avatar
The most useful tool I had for my header install was a foot and a half pipe that sleeved my ratchet. Made the manifold bolts a lot easier to get off. PB Blaster or WD-40 is definetly good to have. Since you're deleting the AIR you'll need a Dremel to cut the metal AIR pipes.
Old Feb 24, 2005 | 09:59 AM
SS#771's Avatar
why would u have to drain your oil????
Old Feb 24, 2005 | 10:35 AM
Dave89IROC's Avatar
needs to pull the filte anyway, might at well change the oil too
Old Feb 24, 2005 | 11:03 AM
SS#771's Avatar
doesnt make sence to me on the oil....why spend 25 extra bux when you can take out the filter and add maybe half a quart of oil if your not due for an oil change....
Also something soft yet somewhat firm to take your frustration out on in times of being pissed at your car.....piece of wood will work
Old Feb 24, 2005 | 11:10 AM
Spinner's Avatar
I dont guess you HAVE to drain it, but the filter does have to come off.
Old Feb 24, 2005 | 11:49 AM
97BBlackZ's Avatar
Well thats good to know. Is there any place that i can get a dremel and a power saw, I would prefer to rent one.. Would home depot have that?
Old Feb 24, 2005 | 12:14 PM
FryedClutch's Avatar
one thing i would recomend you getting that i wish i had ewhen i put mine in is a set of those ratcheting wrenches they would have made getting the headder bolts tight so much easier
Old Feb 24, 2005 | 05:38 PM
keng's Avatar
SO what do you do about the egr or smog pump that hooks up the exhaust?
Old Feb 24, 2005 | 08:22 PM
Deckstripes's Avatar
nice timing. I just pulled the passenger manifold on my 97 Z, installing SLPs. Like 20 minutes ago. Anyway, 1/2 inch combination wrench got that egr tube, do it after pulling the manifold bolts for better clearance against the trans dipstick. Don't think I could have got it with the Y pipe on. A 14 stubby was real handy a couple times. For you, I recommend a nice buzz to numb you out of your misery. This job ranks right up there with changing an automatic trans. Good luck.
Old Feb 24, 2005 | 08:43 PM
TobyZ28's Avatar
I second that, its probably my useful and cheapest tool "addon", a pipe i got at the hardware store that sleeves over my normal wrench. Sure beats buying a breaker bar lol...
Old Feb 24, 2005 | 09:17 PM
SickWS6's Avatar
you do not need to take the oil filter off you can work around it. just give yourself plenty of time and you are going to need a lot of patience, your starter will need to come off, and you will most likely have to jack the engine up, its a bitch to do but definatly worth it
Old Feb 24, 2005 | 09:23 PM
97BBlackZ's Avatar
What did yall do about the AIR and ERG system? I don't have any block of plates that i can use right now so what can i use instead of that? Also i have the cut the pipes for it?
