View Full Version : LT1 Based Engine Tech
- What 02 sensors to use with LT's?
- Changing Thermostat
- 120 Mph Sound
- HELP me diagnose my gas milage problem
- Wiper motor install problem
- xe 230/236 or not?
- Running A Cat
- locking lug nuts
- How much assembly for moser rear?
- new to the forum, just bought a 96 Z
- Removing paint from intake manifold
- Why do our cars have three fuel lines?
- LT4 Knock Sensor question
- SLP fan switch
- Strength of 93 G92 T56
- Results from compression test!!!!
- Headers?
- how much hp can I get with a cam
- Strange vibration- PLEASE HELP!
- Ugraded posi on Strange unit...
- put me on the road to 380RWHP please.
- How long will our air conditioning systems last?
- Gutting Cat
- 160F thermostat
- anyone hear of durabond cam bearings?
- forged pistons
- Traction Control on 97 Formula
- rearend?
- what exactly does the fluidampner do?
- whats the difference between the lt1 balancer and the lt4 balancer
- floor jack
- PartNumber Gold Crane 1.6 RR's
- changing fuel filter w/a full tank
- New gaskets needed when removing valve covers?
- My car wont start....
- Need help for an answer
- Idle drop
- Need Front Brake Line Diagram
- Gig I hurt anything please help????
- split o2 readings( is this too much)?
- I Have The Worst Luck On This Forsaken Earth!!!!!
- How do you bleed the McLeod Slave cyliner
- 93 computer upgrades
- Will 97+ C5 Wheels fit on an 94 F-Body?
- fuel pump or opti?
- How to remove broken rad. drainscrew?
- Need a part number!
- What is normal fuel pressure PSI?
- why does my car stumble at low RPM?
- Loudmouth fail tech?
- Dual Fan tech question
- Can stock mAF make you lean out?
- Anybody running a "shuttleworth" muffler?
- A4
- Have a question about my exhaust setup.
- I need the part # for a lt4 km??
- Is my cam too much for this supercharger?
- M6 flywheel question
- Is it just me (zip ties and tranny cooler)
- Options for dual-cats on Jet-Hot LT install?
- shifting points for HD 4L60E with shift kit??
- Rear Brake Pads Question
- suspension question?
- what makes spark plugs turn green??
- What PSI are you running in your ET drags?
- Is this all I need for opti & waterpump replacement?
- anyone seen a good LT1 or small block book???
- Smog okay? With xe224/230.
- ac-delco spark plug wires???
- changing clutch...what else do i need
- wheres a cheap place to buy t-tops and door seals
- Ruff Lt1
- Shift point for stock with M6 ?
- hey drivefast4fun
- launching
- gasket ?
- weather
- ? about coolant line to pass. head
- fan operation
- Converter Lockup ??
- BMR Relocation Brackets????
- Injector question
- HELP Dynoed today wierd numbers????
- Can a stripped spark plug hole affect performance???
- Are SFC's necessary w/ 6 point cage?
- Loose drivers mirror
- part numbers needed
- Brake light Q?
- Rings/Bearings/Oil Pump Questions
- Strut Tower Bar
- MAF Cleaning, what to use?
- 32 Valve Heads for LT1 or LS1?
- brakess
- Do salad shooters fit mid 80's Camaro's?
- cruise control lever
- 1994 z28's have 24lb injectors right????
- Rear end install guide?
- AIR Foils and thorttol bodies
- 95 Z28 woes
- Suspension experts: Bilstein, or KYB AGX adjustable shocks?
- LT4 conversion
- driving in deep water...
- How much spring sag do I have after 6 years?
- 4.10 M6 Guys...
- Help me choose between Hotcam and CC305
- What Tranny mods should be done for a H/S Tourqe converter
- Sea Foam = Worse Mileage
- Random Rear Brake noise
- Oil Filter bypas
- Swapping LT4 springs
- Lost 5th 6th and Reverse???
- long tube hooker dual exhaust set up
- Spec Stage II questions?
- where to buy these?
- how hard to change springs/shocks?
- Batch fire VS sequential
- New Clutch
- Prothane Motor+Tranny mount part #'s?
- good camaro z28 ?
- Seriously odd syptoms
- putting 3" to 2" reducers on the end of my true duals for more backpressure?
- Is it time to upgrade injectors?
- have problem with car...maybe vacume leak?????
- sounds like fire crackers in my exhaust!!
- Cars Accs wont come on
- LT4 valves
- Just got back from Track. May have shifting issues...
- thinking of buying another LT1
- question about the shifter
- Signs of a bad opti?
- question about borla exhaust
- 3/8 and 7/16 RR's fit on either size stud?
- Is there a spring kit for the CC306?? Also what other parts?
- peak mph with 3.73's vs 4.10's in 4th gear??
- need help with 4l60e
- value of totaled 94z?
- DISCUSSION::Highest compression on pump gas??
- dont shift into drive from reverse and hit the gas
- Better to use stock RR's rather than 1.6's with cc306 on stock heads??
- not rebuildable short block
- What is the A.I.R. pump?
- Gut or remove Cat?
- Removed compressor, added new pulley, need new serp. belt length?
- tranny acting funky..
- Kickdown
- O2?
- flange kit for LT1 heads?
- hot temp miss?????
- How in the world
- Weld Pro-Star XP's?
- auto
- Goofy ABS Sensor Light
- 93 formula with TH-700-R4 trans help
- Replaced the Rad Cap.
- where can I get new stock wp housing
- Are bigger tires better?
- new engine
- ATI Damper
- adjusting throttle blades, ???
- Update on my motor
- carsound/catco direct replacement ?
- PCV was plugged should i worry?
- antenna wont go up??
- Have question about Pro 5.0 install?
- Question about an EGR leak!
- 58 or 52 tb
- quick I need to know....
- Need help asap how do i remove the air pump to install taylor ovc wires??
- Part Number/Fuel Pump Question
- head porting in Canada
- Need Help Removing Gauge Cluster
- how much power can a moser 12bolt hold
- What do you think of this 383 for my goals? any sugestions?
- How do you clean the IAC?
- CAREFUL JACKING UP MOTOR!......please read
- Where is the best place to buy an opti for my 94z28?
- true duals with AS&M midlengths, is it possible?
- windshield replacement
- Driveshaft question?
- coolant light wont go off
- Help, fuse keeps blowing
- 94 z28 rear end noise (bumps in driveline slack)
- Felpro Head Gasket - 2 types/ deck heights?
- Small leak
- Havng trouble taking shifter off
- Best place to remove a quart of tranny fluid?
- quik tranny ????
- confused and needs help?
- Please Help Asap
- halfway through longtube install and have a couple questions...
- Best place for 1le elbow?
- Will Ford 35# injectors work with LT1?
- Y-Pipe for 97 LT1
- Need Technical help with HIGH idle issues...Please
- turbo 400 conversion
- where to find exhaust hanger bushings?
- Anyone ever have an A4 chatter in reverse?
- How many fuel filters are there on my 97 Z?
- how do yuo diconnect the throttle and cruise cables from tB?
- Where should the power peak in my motor?
- First time at the track what do you think?
- Hesitation.. wires.. and more..
- Ball Bearing Oil Gallery Plug??
- ABS inop and air bag light fixed.
- Question about actual exhaust piping
- What is a good head porting book?
- put the gear in neutral, rev it up a little bit, the SES comes on, then off
- strange elec. problem
- ONEQUICKTA2=good seller!!!!!!!11
- how to tell if injectors are HIGH Z or LOW Z?
- OK what in the hell does an oil/pcv breather do for the car???
- Horsepower
- spohn torque arm
- What can I use to fix a crack from the airbags going off?
- who used thes tires
- how do you lock the blms with TC
- Plugs........is it really that hard????
- Cat Cut-Out on a 94 T/A???
- changed my plugs and wires... well 4 of them
- Flywheel resurfacing
- Problems after mods
- Getting Knock Retard...What to do?
- In thory which would give better flow?
- how many liters your z28 need?
- supercharger? do or dont, and what needs to be done to handle it
- best way to hook up fuel pressure gauge
- Car is very hard to get into 6th gear! What is messed?
- M E/T streets or H Q/T?
- Help!
- Borla Diferences?
- Which Headers To Get?
- 10PSI SC 93 Z on ebay ... STOCK BOTTOM
- GM additive...Is the autozone ok?
- odd starter problem
- Would dilectric grease change the resistance of my msd rpm pills at all?
- BULL****! My dash plastic cracked for no reason: LOOK PLEASE
- Struts
- What are the symptoms of a bad opti?
- True Duals: I need "how to"
- Switching ASR over to non ASR?
- What are the symptoms of a bad map sensor?
- blown head gasket???????
- Auto trans needs work. should I switch to 6 SPD?
- Roller rocker size question
- Driveshaft Safety Loop with Duals?
- Evaluate my engine combo plz...
- Dual filter Oil filter????
- Its got a big Crack!!!!
- where to buy lt-4 knock retard
