HELP Dynoed today wierd numbers????
I have a 96 TA with mods in my sig here were the numbers
287 hp @5000rpm
315 tq at4400rpm.
The graph is choppy throughout the whole hp and tq curves indicating an ignition problem? I have stock wires and plugs with 67000 miles.
Here is the kicker the AF ratio was pretty steady at 14.8 to 1 very lean. I had the pcm tuned and he leaned the mixture out bc he said most lt1's run rich could that be the problem.
I am gonna do MSD wires and NGK plugs tongiht will that help out at all?
I am actually kind of happy with the numbers considering the misfire and a lean aF what do you think it could make?
287 hp @5000rpm
315 tq at4400rpm.
New wires and plugs could help solve your problems. But the thing that stood out to me is that you made 287rwhp @5000rpm, and you have a Hotcam!!!! Most Hotcam equipped z28's make power all the way to ~6000rpm, even higher in some cases. That is what that cam is made for. I think you need some more tuning done to take care of that. I think you have at least another 25-30rwhp out of that setup. Good luck.
That is a little better.
Those numbers aren't too bad man, just take care of the small stuff like the plugs and wires, get the car tuned a little better, and you will see much better numbers.
Good Luck.
Good Luck.
the dude at pcms for less leaned the af out slightly he said should I reverse this or with newe plugs and wires could that fix my AF ratio the AF is pretty steady it dosn't jump much what do yuo guys think?
if your saying that the car was running 14.8 a/f ratio at wot throttle. that is way to lean it needs to be about 12.8 to 13.1. he leaned it out way. WAY TO MUCH. in closed loop is 14.7. wot or open loop is factory at 11.7 to 1 af ratio. i personally would not run that car at wot throttle till you get that reprogramed. your running leaner in at open throttle. than in closed loop
hey i will fix it for you at no charge if your willing to meet me half way im only about a hour and a half. but honestly the best thing to do is go get it tuned on a dyno with a wide band 02
sorry just relized your obd2. sorry i tried to help.
