Need help asap how do i remove the air pump to install taylor ovc wires??
Old Jul 22, 2003 | 04:36 PM
speed76demon's Avatar
Took my car to the shop to get the plug wires done and the guy said he couldnt run them on the passenger side b/c the air pump was in the way. Then he said that after he removes it the serpentine belt will be off. So any ideas on how to get this done?? Please help me i just want to have my lt1 running strong again
Old Jul 22, 2003 | 04:39 PM
Also will i have to get my pcm programmed so my ses light doesnt come on??
Old Jul 22, 2003 | 04:43 PM
Z95m6's Avatar
the air pump is on the drivers side. I assume you are talking about the power steering pump. Don't run the wires in the stock location by the PS pump. They can be installed without taking the ps pump off, but just route them over the valve cover. I wasted 2 hrs putting the wires in the stock location on the pass. side and after they arc'd all over, damn taylors, i ripped them off in place of MSD's OTVC.
Old Jul 22, 2003 | 04:46 PM
now he is routing them ovc but then when he goes to take them down to the opti there is no way he says to get down there without removing the AIR. I have also noticed that my car is a early 94 car i think b/c of other things that has happened to me that are diff from other 94 cars still no ideas on how to route these it looks to me like he is right the passenger side is so crowded i dont know how he could do it any other suggestions or pics of how u did it
Old Jul 22, 2003 | 05:47 PM
G's Z28-LT1's Avatar
Just curious, where did you get the MSD OTVC wires??? Are they pre-crimped or universal?
Thanks.
Old Jul 22, 2003 | 05:50 PM
Z95m6's Avatar
You can get the MSD's through summit. They are universals and they had them in stock. jegs told me they would take 3 weeks to order and get some.
Old Jul 22, 2003 | 06:19 PM
revtime's Avatar
Your AIR pump is driven by the serpentine belt?
I have never seen this.
I think you should be able to remove the AIR and be done with it.
Thats what I did.
Look on there and see if your AIR is driven by a belt, I would like to see that.
Old Jul 22, 2003 | 06:43 PM
gb95zconv's Avatar
The AIR is on the drivers side and is not belt driven....its electric. Take it off and throw it away...it want light the ses. The wires are easy to run on the drivers side in the stock location. Now the passenger side is a different story....I put plastic wire sheilds on the wires on the passenger side and routed them between the acc bracket and engine the ziptied them where I could....no problems after 2 years . The only thing you need to remove for the passenger side to do this is the belt and belt tensoner...very easy.....just make sure to shroud the wires.
Old Jul 22, 2003 | 06:48 PM
revtime's Avatar
That is exactly what I did.
Very important to put some convoluted tubing on the wires that go through the brackets on the passenger side, they will chafe and eventually rub through the wires outer coating creating an arcing condition.
Old Jul 22, 2003 | 06:53 PM
CamaroBoy96Z28's Avatar
Same here. I couldnt see how you can rout the anywhere else. Wherever I thought the wire would touch any metal I used convulted tubing. Other than that it was really easy, just removed the tensioner. Driver's side, the wires go through where the AIR pump used to be.
HectorM52
Jul 30, 2017 11:46 AM
95chwagon
Jan 13, 2015 09:19 PM
cmdeshon
Dec 27, 2014 10:06 AM
GigaMp3z
Feb 20, 2003 02:57 PM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
