58 or 52 tb
Old Jul 22, 2003 | 04:49 PM
hot936spd's Avatar
58 or 52 tb
wondering, if a 58 tb would be good for my car. would it work with out a ported intake. or would it be messed up, ,i know its not that noticeable, with out head work. but does it help throttle response, or smoothness at all?
93z- 4.10s, cai, 1.6rr, bbk shorties, pulleys, thermo stat, chip, lcas, sfcs, alum shaft, short shifter, ,new clutch, full exhaust, motor/trans mounts.
Old Jul 22, 2003 | 04:53 PM
95TA8280's Avatar
Most people with strog heads/cam combos still run on the stock TB. Certainly not worth the $350 or so they charge, as some people will argue it costs HP, not gains you it. When you get a 383 or 396, thats when you need a bigger TB, Till then, don't worry about it
Old Jul 22, 2003 | 05:03 PM
Jeff Belloma
Guest
Posts: n/a
i picked up 8 rwhp and 12 rwtq (about 6 avg HP and 9 avg tq through the revs) swapping from a BBK 52mm to an arizona speed and marine 58mm. that, from my last engine, a 355.
JB
Old Jul 22, 2003 | 07:28 PM
wicked_95z's Avatar
On the original motor with just about every bolt-on, I noticed a significant increase in throttle response when I installed my BBK 58 mm. However, like it was stated already; it's not worth $350 if you could buy headers or roller rockers instead. I paid $150 for mine, only reason I snatched it up.
Old Jul 22, 2003 | 07:33 PM
IrocManiac's Avatar
Not worth it unless you're approaching the 400rwhp barrier...then maybe...
Old Jul 22, 2003 | 11:13 PM
hot936spd's Avatar
is a holley a good brand to get, for a 58 tb?
what i , could pick it up fairly new, for around 200-250 would it be worth it, thanks
Old Jul 22, 2003 | 11:41 PM
FacelessZ's Avatar
I'd do BBK before Holley....Holley has been known to have some problems with sticking blades.....
Old Jul 23, 2003 | 12:14 AM
hot936spd's Avatar
anybody esle, have trouble with holley tb, or is bbk better, but if i can get for like 200 or 250 $ should i do it
Old Jul 23, 2003 | 12:31 AM
93formula's Avatar
well you dont really need it, but if your gonna mod in the future and can find one cheap, go with a bbk 58mm. you will however definatly need to port your intake to match the tb.
here you go:
http://www.bfranker.badz28.com/96ss/58porting.htm
Old Jul 23, 2003 | 12:47 AM
IrocManiac's Avatar
You'll always be able to find those fairly cheap if you look...I'd wait till you honestly need it otherwise its a waste of 200 or 250 bucks if you never use it or never see more than a 2rwhp gain out of it.
Old Jul 23, 2003 | 12:58 AM
Antz97ZNJ's Avatar
your stock is fine spend the money elsewhere
